where to buy new battery terminals?
Old 03-10-2008, 01:11 PM
GoldenBeaR6's Avatar
Hey fellas,
My battery terminals are BADLY corroded. I want to replace them before they disintegrate completely into dust. The parts store didn't seem to carry anything that resembles the stock positive terminal (the one with about 3 wires going into it). Do I need to buy this part from the dealer?
Thanks!
Old 03-10-2008, 01:20 PM
sh0kk86's Avatar
thats probably the black/neg cable and it should only have 1 coming off it for the ground to the fender?
i got mine all from vatozone.
Old 03-10-2008, 01:27 PM
Ringmaster's Avatar
Any parts store should have battery terminals. They won't be the same or as good as O.E.M. but they'll clean up the corrosion problem.
If you buy a set and install them, coat them in some sort of anti-corrosion compound to help keep the green beards from forming.
They can be had a brush on type, or aerosol type, I prefer the aerosol type.
Old 03-10-2008, 01:43 PM
No, I'm talking about the positive terminal underneath the red plastic cover thing. In theory I could jam all 3 wires into the input of a standard terminal, but I'd like to keep the stock setup with the wires connecting at different points.
I have the dielectric grease ready to go as soon as I get the right terminals.
EDIT: if this is sounding strange to y'all, maybe my positive terminal is not stock. I'll try to take a pic when I get home tonight.
Old 03-10-2008, 03:17 PM
olharleyman's Avatar
You should be able to get a set up with the clamp down running from side to side so you can add the extra wires from any autozone napa autoparts store its not a rare or even dealer only style/type clamp. Just go in to the auto store and explain to them that you need one for multi wires to the battery.
Old 03-10-2008, 03:21 PM
DudeBud's Avatar
you can get nice battery thermals from a stereo shop. toyota oem battery thermals are garbage, in my experience they break easy and don't hold up to corrosion very well
Old 03-10-2008, 03:56 PM
sleaz22xx's Avatar
i went to autozone and got two different sets of terminals, one set had cheesy terminals but quick disconnects like a bike wheel, the other had thick color coded terminals that bolted, i used the thicker terminals with the quick disco's to make somthing inbetween, they have a really good connection and allow you to disconect the terminals with out a wrench, i like them, they hold really tight and are super convenient, if you really want the best connection you need to go with gold terminals from a stereo shop like the PP suggested
Old 03-10-2008, 04:02 PM
ARSmay's Avatar
Go for the marine grade brass version, totally corrosion resistant. Any chain parts store or walmart.
montanatruck
02-26-2017 07:07 AM
Regency
09-04-2015 01:32 PM
RobotMoose
09-02-2015 05:53 AM
80Truck
07-24-2015 03:12 PM
luckypig44
07-19-2015 11:25 AM
Quick Reply: where to buy new battery terminals?
