when does the cigarette lighter turn on
Old 09-27-2008, 10:34 PM
SR5
SR5's Avatar
some times ill be driving and see it on and sometimes its not?
Old 09-27-2008, 10:42 PM
iamsuperbleeder's Avatar
should stay on whenever you have the ignition turn all the way to the running position... unless there's a short somwhere...
Old 09-28-2008, 12:20 AM
SR5
SR5's Avatar
oh man, i hope i don't have a short
is their a way to pin point the short, ill check my fuses first thing tomorrow and see if thats it
thanx for the info
Old 09-28-2008, 08:26 AM
maybe not so much as a short, but maybe a bad ground or bad connection at the plug on the back of the lighter plugin.
if you have the time, pop the dash apart and make sure that plug's on good and the contacts are clean.
if still no luck, you can always just rewire it; it's not that difficult to do on that, just make sure you don't flop the hot and ground backwards
I've done that with some other vehicles in the past when the lighter for some reason quit working. you can even just run it on constant power if you wunna keep it hot all the time, like if yoiu want to leave your cell phone charging that extra 10 minutes while your out of your truck. hell, you could go all out and even put a toggle switch in the dash for it
Old 09-28-2008, 08:33 AM
Fink's Avatar
This might sound like a stupid question but how are you telling whether it's on or not?
Do you have a gadget plugged in or something?
I know with mine there's no way I'd be able to tell it was on - I have my fire lights plugged in but I have to hit a switch for them to turn on.
Fink
Old 09-28-2008, 08:55 AM
Fink
just for the record, I have a 6th sence; I can tell when metals are energized with 12v simply by looking at them
yeah I would only assume he's got something plugged in. but don't the SR5's have a light there to? does that stay on with the plugin? maybe that's what he's seeing flickering, but the power to the plug may be fine
Old 09-28-2008, 08:57 AM
Fink's Avatar
That's why I asked - there are a lot of variables.
Of course, that 6th sense I'm sure helps a lot.
Could be that the plug isn't in the socket tight enough, could be something wrong with the gadget he's got plugged in, could be a loose connection in the dash, etc...
Fink
Old 09-28-2008, 12:23 PM
SR5
SR5's Avatar
ya im talking about the light in thier,
i recently changed it to a blue LED and i have not seen turn on,
but before i did that, the light only came on at random times,
Old 09-28-2008, 12:26 PM
4Crawler's Avatar
Should be on with the dash lights. Could be if you have the dash lights dimmed very far, the LED may not turn on.
Old 09-28-2008, 12:29 PM
SR5
SR5's Avatar
ive tried that, and it still wont turn on
Old 09-28-2008, 12:30 PM
SR5
SR5's Avatar
im thinking if i plug like a cell phone charger into it, and pull lit out, it would turn on
Old 09-28-2008, 12:47 PM
Fink's Avatar
I don't think they're that smart.
It should either be on given a single variable or off given a single variable.
Roger's right, it should definitely be on with the dash lights.
Something may have happened when you did the LED swap but if it did indeed come on at random times even with the stock bulb - there may be a more complex problem.
You may plug something in - like a cell charger and do a few "wiggle tests" to see if it stays on or off or if it's intermittent.
Fink
okamikai
04-30-2018 10:19 PM
Dakotaneu
08-15-2015 07:24 AM
Mrhoadley
08-04-2015 06:08 PM
TDonkey
07-26-2015 10:14 AM
Hamonacracker
07-17-2015 08:33 AM
Quick Reply: when does the cigarette lighter turn on
