When adjusting 3vze idle speed, do you adjust idle air screw, or throttle screw?
There are two screws i talking about, the one that is built into the TB (idle air screw?) and the one that stops the throttle.
I adjusted my timing to 16 * btdc and fixed a unmetered air leak, now it idles around 1500 in neutral; and 1100 in drive.
Ok, good cause I lost a couple allen wrenches and broke a couple flashlights trying to adjust the other one. Should of asked first. Thanks Mudhippy
