Wheel vibration??
Old 01-22-2016, 08:43 PM
greasyglue's Avatar
Wheel vibration??
Hey so crazy thing, did a whole bunch of front end work, wheel bearings inner and outer brake calipers rotors and CV axles, I have a vibration in the front end and I'm wondering if it has to do with the driver side wheel bearing I followed procedure and everything do I just need an alignment I don't have any significant pull, when I replaced the drivers side cv axle it eliminated the hard pull to the right when engaged in 4x4 and replaced it with a slight pull to the left....but in 2wd I almost feel like like tire becomes egg shaped for seconds at a time...what the hell is going on?? Suggestions? I fish scaled and preloaded and everything...what the hell is it???
Old 01-28-2016, 01:07 PM
kcaudill's Avatar
How big are your tires?
Mine did that at freeway speeds, but im running large tires 33 12.50 and it gets a small wobble then goes out of control wobble.
Old 01-28-2016, 04:44 PM
bpealer's Avatar
Yea I would check the tire balance first. Maybe rotate the tires around and see if the problem is still there.
Old 01-29-2016, 06:05 AM
Snowking's Avatar
What year? Ball joints??
LucasF249
02-23-2016 12:12 PM
MorphiasX
12-02-2015 10:00 AM
surf4life
11-28-2015 03:32 PM
jhsantacruz63
11-24-2015 06:04 PM
pplusent
11-04-2015 05:14 PM
Quick Reply: Wheel vibration??
