Wheel or tire problem?
Old 04-11-2008, 04:36 PM
ads86runner's Avatar
I am running 31x10.50x15 on my stock aluminum wheels (check sig). Having trouble keeping them balanced and the wheel shakes over 50mph. The TIRE MAN says you need to run a 8in wheel with that tire and that that was the problem. He also said those older type aluminum wheels were hard to balance. The tires are new with only about 8k miles on them. Anyone else have this problem on 8in wheels?
Old 04-11-2008, 04:47 PM
leebee's Avatar
i have the factory alloys with 31's and they balanced up quite nicely, thank you very much. it is possible that your tires might be out of round and therefore leading to the balancing issues you are experiencing.
if possible, take your rig to another shop for a 2nd opinion and get the results in writing in case you need to have tires replaced. good luck and keep us posted.
lee
Old 04-11-2008, 04:51 PM
bigarms23's Avatar
the only way they wouldn't work is if the rims themselves are bent or tweeked. but the stock rims should work fine so get that second opinion
Old 04-11-2008, 07:41 PM
norcalsvx's Avatar
take it somewhere else i used to balance that combo all day long (unless the wheel is bent but you would be able to tell)
Old 04-12-2008, 07:30 AM
Yea, ill take it somewhere else maybe this week. I guess its possible to have a wheel out of round or bent. How much psi you guys running and does it make a difference if weights are on the inside? Thanks for the help!!
Old 04-12-2008, 07:47 AM
norcalsvx's Avatar
i run 30psi on the street, no i doesnt matter where the put the wheel weights
BushPig
10-29-2022 06:26 AM
06-01-2021 01:51 PM
skoti89
07-06-2015 07:45 PM
MTLroadierunner
07-06-2015 12:17 PM
Quick Reply: Wheel or tire problem?
