Wheel spacer/Ball joint spacer/ alignment help?
OK.I installed BJ spacers. the pic shows the room I have between tire and A -arm. MY question is. Is this enough room or should I get wheel spacers ? This pic is without an Alignment I am afraid I will loose more space if adjustments are needed with the alignment.
If your camber is like this / \ or this l l , you should be ok after the alignment. If your camber is like \ / you might have a problem with rubbing after the alignment.
From my experience it's when the front suspension is fully extended or compressed that the touching may arise. I suggest you disconnect the front & rear sway bar & jack up the car from one side of the lower front cross member compressing the other wheel into the bay and fully extending the other off ground. Rotate the raised wheel and look for any fouling, and check there is sufficient space between the arms on the compressed side. As most tyre bulging happens at the bottom make sure you have plenty of clearance there. If plent of space at the bottom & no touching up top, you don't need the spacers or a grinder. Do both sides, as oddly enough one side on my car touched slightly, the other cleared the tire (possibly related to the Procomp lift spindles that I have along with the BJ spacers).
As to the effect on the bearings yes wheel spacers may decrease their life span, as would larger oversized tyres with more offset. More importantly offsetting the wheel further out impacts on braking, as in theory the disk is meant to be as near to the centre of the rim as possible to give stable braking. How much negative effect there is on braking by moving the disk away from the centre line of the wheel I can't answer, but its for that reason alone wheel spacers are not legal in the state I in live in Australia. May be better to stick with the grinding if its only a slight touch for that reason alone.
Don't forget that new rims with different offset can fix any touching issues also, but a real slim wheel spacer is usually the chapest fix.
Cheers, Darrie
Cheers, Darrie
Im your camber is out, then you might have an issue. I would grind the lip off the UCA and go get aligned. Check for rubbing/clearance after that. If you dont have more then .5" or so, I would either get a set of wheel spacers or new rims will less backspacing (around 3.75")
Wheel spacers are not the best way to go, but they will work in a pinch. Just dont get cheap ones that slip over the lugs, this is dangerous.
Just cut off that lip, better be safe than sorry. I might re-enforce a-arm there a bit afterward if you have access to a welder. Big wheel spacers increase the load on wheel bearings (bad), but smaller ones should give you the clearance you need without putting too much load on the bearings or shorten the effective length of the wheel studs too much.
I had the exact same problem after installing my BJ spacers and 16" rims, 5" backspace. I have some 1/4" spacers if you want them ($10 ea), I went to 1/2" billet spacers with longer studs. I'd say trim that A arm a little (just the edge), and then put a 1/4" spacer on the hubs with the stock studs. Run it! (*see thread titled 'wheel spacer debate')
Up&Down
08-05-2015 06:20 AM
coffey50
07-28-2015 10:55 AM
