Wheel Question
Wheel Question
I have a white 94 2WD, I need to get new wheels (the ones it came with are mis matched alloys) I'm thinking about doing white steel wheels, but the only ones I can find are the wagon wheel type, am I crazy or did they also make the Outlaw II type wheel (with the round holes all around) in white? Anyone know who makes them and where to get them if still available?
they call it a white modular wheel ...but i believe u will only find it in trailer fitments these days...so if you can live with a 15x6" or maybe a 16x7" you can get it...otherwise your outta luck as far as I know.
Thanks for the replies, this is just a errand/home projects truck anway so I'll probably just go with the wagon wheels unless I get a realy good deal on something else.
Yeah I've been trying there, but haven't found any, that's why I thought I might have to bite the bullet and buy new. As far as bolt pattern I think some years of Ford rangers have the same pattern.
But I've also been busy and it's not a priority right now, the tires are ok and I figured I'd swap out when I got new tires.
Chevy full size trucks I know are the same bolt pattern. the six lug that is. the only problem is the hub size. stock Chevy wheel hubs are too small to fit on a Toyota hub. but that might not be a problem with 2WD. don't know for sure. so an after market set of rims for a Chevy will work because they make the hub size larger to fit more vehicles.
the Toyota hub size is 4.280 and the Chevy slightly smaller.
some people say they just grind them down to make 'em fit but IMO you might have trouble balancing after doing that.
coffey50
07-28-2015 10:55 AM
rushw
07-18-2015 01:46 PM
