Wheel Bearing Replacement
Old 03-23-2010, 11:57 AM
Chutchman's Avatar
I am looking at replacing my wheel bearings this weekend. What brand would you guys recommend? Where is best to get them?
Old 03-23-2010, 12:13 PM
anthony1's Avatar
Toyota. They use the best bearings.
Old 03-23-2010, 12:39 PM
pruney81's Avatar
x2 on Toyota. Are you sure they need to be replaced. I just did my front pads and rotors and my wheel bearings were in good shape so I just repacked them.
Old 03-23-2010, 01:06 PM
Marc's Avatar
IF you need to replace them, then NTN, SKF or Timken are all good.
You can get them at most auto part or bearing places.
Old 03-23-2010, 02:14 PM
highonpottery's Avatar
don't forget to get a 54mm socket so you can properly remove that huge-ass nut and properly torque everything when you put her back together. also remember to use the proper grease when you pack the bearings.
Old 03-23-2010, 02:23 PM
iamsuperbleeder's Avatar
and to pack them correctly
Old 03-23-2010, 02:25 PM
pruney81's Avatar
I picked up a 2 1/8" socket at Sears for $30.
Old 03-23-2010, 04:38 PM
anthony1's Avatar
Marlin got one for 25.00
http://www.marlincrawler.com/hardwar...ls/54mm-socket
Old 03-25-2010, 09:05 AM
i got mine from WabFab along with the bearing kit he sells.
Old 03-25-2010, 01:54 PM
toyospearo's Avatar
x2 on the Wabfab set up. I got mine there and I am about to order the same kit for my buddies 83 and my new 82!
bigjstang
08-25-2021 12:41 AM
mskalmus
05-28-2017 07:51 AM
Gamble_STi
07-07-2015 07:54 PM
skoti89
07-06-2015 07:45 PM
colinmil
07-06-2015 04:03 PM
Quick Reply: Wheel Bearing Replacement
