Whats that peice called???
Old 02-18-2009, 10:22 PM
Countryhick's Avatar
the one that you plug car lighters into and stuff??
im to tired i cant remeber.
im trying to find out somewhere that has one mines completely not working. ive checked all my fuses.. over and over.
Old 02-18-2009, 10:24 PM
abecedarian's Avatar
cigarette lighter receptacle?
Old 02-18-2009, 10:25 PM
is that it?>? im trying to findout if napa or schucks has one.
if not off i go to the junk yard.
Old 02-18-2009, 10:31 PM
you might also hear it referred to as a 'well'
Old 02-18-2009, 10:34 PM
scuba's Avatar
Dude, look in there and see if the little contacts are pushed in, if so FOR YOUR SAFTEY, Disco your battery and stick a flat head in there and jam them inwards, then your garmin or whatever your trying to plug in should make contact.
Old 02-18-2009, 10:50 PM
aaron26889's Avatar
napa sells them just tell them you need the thing that the cig lighter receptical. mine was under 5bucks
Old 02-19-2009, 07:31 AM
qdude79's Avatar
Had the same problem with my '90, pulled the "receptacle/well" and saw that there are two wire leads on the back, one of them blown/separated. Wanted to go the easy route, went to a parts store for a generic replacement. Got it home and went to install it, but it didn't fit right. It was a bit smaller than the stock hole and backing, and had no place in the backing that came with it for the small dash light that goes there originally. Decided to return the new one and got some electric solder. Good as new, and even saved a few bucks. Might consider...
Old 02-19-2009, 01:45 PM
iamsuperbleeder's Avatar
you can repair these you know, and it'll make the fix permanent. I did it for a guy once when I worked at Advance Auto Parts. I guy in a Taco said first one plug in stopped working, then the other stopped working; cause he was running a freek'n coffe maker off them but mine went out while using a cheapo air-pump once. You have to remove the whole thing, unscrew the bottom of it, remove a non-conductive washer, and reassymble. That really doesn't tell you much.. it's hard to explain, and it's been a while since I've done it... but it takes the fusable link thingy on the end completely out of it.
if I knew this was so much of a problem as it appears to be, I would have done an in depth, step by step how-to post...
Firefightersink15
11-23-2015 10:32 PM
Chicken12
10-14-2015 03:54 PM
LCE_Performance
10-01-2015 01:03 PM
JookUpVandetti
09-30-2015 08:58 AM
93RedKrawler
09-25-2015 02:41 PM
Quick Reply: Whats that peice called???
