whats the cheapest way to get a little more powerout of a 22re
i already have a k&n and custom exhaust on my pickup. what else is cheap and easy to do to get more power?
it was only a matter of time, lol
I'll just say this... my current 22re rebuild in progress is costing my well over $1,500, and once done the truck will have a head with over-sized valves for better flow, an LCE intake tube (not to be confused with a cold air intake; the kit retains the stock filter box), .03 over bore, and PaceSetter exhaust from header to tip, and I expect to see under 150hp still...
Quote:
Originally Posted by Slowstrike
Advance the timing a few degrees and run higher octane fuel.
Perhaps, but advancing the timing may cause it to ping and the higher octane fuel may address that, to a point.
In general, running higher octane fuel in an engine that doesn't require it will cause the engine to actually produce a little less power, certainly not more.
Basically all that higher octane fuel does is burn slower.
Fred
i think i saw something about a "supercharger" off ebay for only 4.99 or some crap like that....
https://www.yotatech.com/forums/f5/r...-funny-184265/
this guy may have some good advice about cheap mods for power.....
precisely my point. If you advance the timing you need to higher octane to advance to the point of benefit. Usually I will advance to the point of pre ignition then back it off very slightly untill it is eliminated. Then run a higher octane fuel to ensure I am not getting pre ignition since it has more compression resistance. When I have done this myself with the 22re I have always gotten very noticeable response gains (not necessarily power gains). Anyway like the tittle says for a 2.4l 22re not a 3.0l 3zve.
its kind off pretentious to assume that it is a coincidence that suggesting timing advance and higher octane fuel in the same sentence have nothing to do with each other.
Take the hood, fenders, doors, spare and bed off and tell the passenger to get out then only run one (1) gallon of gas at a time and I gaurentee you'll have better 0-60 times.
These mods should cost you nothing, unless your truck gets impounded for looking like an abandoned vehicle.
Twaddle,.......... keep it near stock, keep it simple. Thats the reason for the 22re's longevity,OEM. Now, not to say i have not modified mine, but after 22 years its still a daily driver, what can i say. Just me .
