What in the world made my spark plugs....
Old 08-20-2008, 04:14 PM
wardriver's Avatar
What in the world made my spark plugs turn brown?
So I'm driving in my neighborhood and then all of the sudden spudder spudder spudder....like I was running out of gas or not on all 6 cylinders. 1/2 tank of gas - so I go and pull the #1 and the #4 plugs and they are both brown. They were replaced w/in the past 5k miles with new wire/cap/rotor/O2sensors...and last week the I installed the high flow cat.
I drove to Baltimore from central VA last weekend and it did just fine...home from work fine...but this is new to me. And I when I pulled the old plug set before these- they were 100% clean - just the electrode was worn to a pin point.
I'm at a loss here....and I can't find my camera. The plugs are light brown, dry and if I scratch the white electrode with my fingernail it starts to chip off.
Any help???? If I find my camera I'll post up pictures. Plugs are NGKBKR5EYA
Old 08-20-2008, 04:29 PM
abecedarian's Avatar
some additives to fuel cause deposits to accumulate on the plugs.
Old 08-20-2008, 04:30 PM
wardriver's Avatar
...the only thing I've added to my fuel is more $ out of my wallet....
Old 08-20-2008, 04:33 PM
TOYOTA 1's Avatar
hahaha,lol...
Old 08-20-2008, 04:38 PM
lol
the oil / gas companies add stuff to help the gas burn cleaner, reduce emissions, etc.
Old 08-20-2008, 05:17 PM
HelliphinoN8's Avatar
Maybe you've got oil coming thru your intake due to a bad PCV valve, (or some bad oil rings). I had that happen to me on my 22RE. Oil dumping into your combustion chambers will definatley cause sputtering. Although I did have a blown head gasket while this was happening, I was told that that wouldn't cause excess blow-by. Who knows! Go get a PCV valve for $3 and see. It can't hurt.
Old 08-20-2008, 06:59 PM
wardriver's Avatar
It the head gasket. That really sucks. Well I guess I'll be sporting my Specalized Allez road bike to work tomorrow....good thing I drive right by the stealership so I can order a good gasket set.
Blamalam
03-12-2022 07:34 AM
jasonty
41
12-23-2018 01:00 PM
old87yota
10-25-2015 02:15 PM
raptor510
08-19-2015 02:15 PM
Sandman
07-14-2015 12:36 PM
Quick Reply: What in the world made my spark plugs....
