What is this and what does it do?
Old 04-03-2013, 07:54 PM
badcompany's Avatar
i've spent the afternoon searching the net and google images and found nothing.
ive searched the entire shop manual (pdf) and found nothing
i want to put oba on my 95 4runner and need this gone to do so...
so what is it and can i remove it?
http://
Old 04-03-2013, 07:57 PM
maachine's Avatar
are those brake lines at the top? what does that bigger rubber hose go to?
Old 04-03-2013, 08:14 PM
badcompany's Avatar
there is a line that goes from p/s pump directly to it, 1 hose and 2 other lines are power steering . then 2 brake lines out the back.....
i cant believe the lack of info on this part.
Old 04-03-2013, 08:21 PM
Co_94_PU's Avatar
2 wheel ABS, 44510 ACTUATOR ASSY, BRAKE
1995 4runner FSM Page BR-57
Old 04-03-2013, 08:25 PM
badcompany's Avatar
dam!
dude thanks now i have an idea of what to do with it.
i dont have abs i changed the rear axle to an eariler model one last year when i did the sas. ok now i know. thanks again
Old 04-04-2013, 04:32 PM
adamthedroog's Avatar
If you're up to it you can remove it. There's a write-up somewhere on it. Type it in on google. Be aware that it disables your ABS which most people say doesn't make a whole lot of difference on these brake systems but I don't know first hand.
Old 04-04-2013, 04:33 PM
Here it is: http://board.marlincrawler.com/index.php?topic=23361.0
Old 04-04-2013, 07:08 PM
badcompany's Avatar
thank you very helpful and informative.
