What transmission do I have? solenoids?
Hello,
I have a 1991 4runner V6 4wd auto, i ordered some solenoids for the transmission but they do not appear to be the same ones on my vehicle. They mount the same but electrical connection is oriented in diff direction and they are smaller. How can I confirm which transmission I have and which solenoids I need?
Thanks for help
Thanks for help
https://www.yotatech.com/wiki/index.php/Main_Page
...check out the wiki page...lots of info
i looked it up ,its a a340h..
Here a few sites for the right solenoids..or do a search on a340h solenoids and see what you come up with.
http://www.bulkpart.com/Merchant2/me...e=A340solenoid
http://www.makcotransmissionparts.com/A340.html
https://www.wittrans.com/showfilter....49&Section=128
these are the solenoids I took out of a donor A340H,,,,,take a look and see if they look like the ones you received?...the black one came from the hydraulic transfer case that I tore down last summer
A340H all torn down even the hydraulic transfer case
Thanks guys, yes those are definitely the same as the solenoids in mine. I was curious because the replacement ones have a ground wire and different electrical connection, but I assume that wouldnt affect anything.
I ordered the ones for A340E and they appear to be slightly different, does anyone know if these will work? these are the ones i had ordered:
http://www.transmissionpartsusa.com/...-00094393a.htm
This site gives you the correct Toyota part number for any part on the truck: http://www.toyodiy.com/parts/ Put in your VIN and only parts for your particular engine/transmission combination will show.
ToyotaMD
09-22-2015 06:28 AM
FS[NorAtl]: FS: NYC 1987 4x4 22RE Engine and Auto Trans
TransAmBandit
09-20-2015 06:08 PM
kelly1450
09-02-2015 12:29 PM
1990, 4runner, 91, a340h, connection, electrical, pn, replacement, selenoid, selonoid, solenoid, solenoids, toyota, transmission, work
