what tranny do i have?
where are the identifying marks for the trans? im about to service it and wanted to be sure i was looking at the correct specs.
i have a 88 p/u 22re 4x4 manual trans.
thanks!
thanks!
Go to your truck, open the door and on the sill, by the door, there is the manufacturer's info. At the bottom right corner, it will say W56 or G58. Thats your transmission. If you have ADD, then from what I've heard, its probably that you have a G58.
its not there. the info plate only has mfg date, VIN, vehicle weight info, and wheel/tire info. no documentation on tranny information on there.
is it not stamped on the trans case somewhere?
84-88 Truck and 84-89 4Runner EFI used a W56 transmission. Easiest way to identify an 84-88 W56 is the top shift plate. It will have 6 bolts holding it down, and 4 bolts holding the actual shifter to the shift plate.
You need to look under the hood to get the correct info plate.
TheBFA
02-15-2020 06:55 AM
live4soccer7
05-11-2016 06:52 PM
hiluxinargentina
09-30-2015 05:51 PM
