What torsion bars will fit?
Old 01-14-2013, 06:19 PM
JonnyBoy's Avatar
As far as them not turning any more, it could just be the bolts are old as crap and stressed, so they're seized. My torsion bolts both broke while adjusting or removing them, and my rig has only been in Oregon, but not near the coast, and high desert of CA. Also, there is a nut on top that some don't seem to have to put a wrench on to stop it from spinning, I did, however.
As far as where to get stock ones, watch Craigslist for somebody who's done an sas and didn't just cut the torsion bars.
Old 01-15-2013, 05:54 AM
96vettelt4's Avatar
LC Engineering has brand new ones for $199.00 and they are probually biggest u will find at 26mm..that will support almost anything..seems lot better to get something quality and new than in a junkyard where you have no history on the part and really 199.00 isnt that much money but its just my opinion...
Old 01-15-2013, 05:57 AM
waskillywabbit's Avatar
Originally Posted by vasinvictor
So just get junkyard replacements. There's lots of us who have stock or cranked bars with no sag. Even 3.4 swappers and no complaints of sagging front end. Cheap and effective.
This.
:wabbit2:
Old 01-20-2013, 03:26 PM
CitrusTheDragon's Avatar
Originally Posted by waskillywabbit
This.
:wabbit2:
From what I gather from Google and other forums the weight difference between the motors is almost 200lbs. From a suspension point of view that's huge and can cause all sorts of issues, not to mention that adds about 6% to the over all vehicle weight. There for the torsion bars should be 6% stronger to support the extra weight. If you add a bumper, winch, and other upgrades. You'll need even thicker torsion bars, but don't believe me.
Let me break it down for you,
22.8 + 6%= 24.17
22.8 x 0.06= 1.368
22.8 + 1.37(rounded)= 24.17
Old 01-20-2013, 03:28 PM
  #25
Theory and reality are not the same.
:wabbit2:
Old 01-20-2013, 03:30 PM
  #26
vasinvictor's Avatar
Perhaps your right but you're making too big a deal out of this. Get stock torsion bars and crank them (6%) if it makes you feel better, to match increased weight. There are hundreds of 3.4 swappers. No issues whatsoever with stock torsion bars.
Old 01-20-2013, 05:00 PM
  #27
:wabbit2:
Don't you own a fab shop? Basic engineering tells you if you put something on a spring that's built to support objects that weigh 6% less then what you have placed on it, said spring will compress more and wear out sooner. It may support it for a short period of time but sooner then later it will fail. If you don't know this I fear for the produces you make in house.
Case in point the rear springs on a 85-?? 4runner. The same springs as the pick-up, but the bushing and springs fail sooner. Why's that? By the way the fiberglass top weighs roughly 150lbs. I guess 200lbs makes a difference over time.
Old 01-20-2013, 05:01 PM
  #28
I made my mind up about a week ago. I just don't like Wabbit or what he stands for.
Old 01-20-2013, 05:09 PM
  #29
You already stated you were too cheap to buy thicker torsion bars you already "know" you need. You were wanting a junkyard solution. Wabbit is a fine fabricator and well respected member of YT. You should pipe down now. No more replies from me on the subject.
Old 01-20-2013, 05:15 PM
  #30
4Crawler's Avatar
22.8 + 6%= 24.17
22.8 x 0.06= 1.368
General idea is correct, but torsion bar stiffness goes up by the 4th power of the diameter:
- http://www.4x4wire.com/toyota/tech/torsion_bars/
For example going from a 22mm to a 24mm bar is a 42% increase in stiffness.
Old 01-20-2013, 05:27 PM
  #31
Are you going to wipe his butt for him too? And I thought he was against gay marriage
Old 01-20-2013, 05:29 PM
  #32
Finally someone with information that can really help. I'll go read that and get a better idea of what I wanna do.
Old 01-21-2013, 05:51 AM
  #33
Liking me is irrelevant to me. I graduated high school 25+ years ago and didn't give a ˟˟˟˟ then either.
How many 3.4 swaps have you done? The fact of the matter of this thread is like most others you've started, you ask questions but then don't want to hear the answers.
There is no need for any greater suspension beef up on a 3.4 swap, 2WD or 4WD. Period.
:wabbit2:
Old 01-21-2013, 08:09 AM
  #34
NickMiller's Avatar
Good 'ol internet drama... Let's keep it on Pirate
Old 01-21-2013, 09:10 AM
  #35
About 4 days ago I asked a suspension tech friend of mine and he told me to just buy some junk yard newer v6 or 4banger ones, about 18 dollars each, because by the time they start to sag again I'll be ready for a suspension upgrade anyways.
Old 01-21-2013, 09:22 AM
  #36
Been welding 25+ years.
BSME 94 University of Alabama
Practicing engineer since 92
Owned WabFab since 05
Basic engineering tells me it's a torsion bar, not a spring. I'd suggest you "How things work" and learn the basic principles of geometry, statics and dymamics and the differences in suspension components.
:wabbit2:
Old 01-21-2013, 09:43 AM
  #37
:wabbit2:
Let's just agree to disagree. We eye to eye on very few things.
Old 01-21-2013, 09:50 AM
  #38
It has nothing to do with agreeing or disagreeing, liking or not liking. It has to do with you simply being wrong.
:wabbit2:
Old 10-25-2014, 06:16 AM
  #39
ironhead's Avatar
All OEM torsion bar parts numbers and acronyms
48162-35040
Spring, Torsion Bar, LH
RN5#, 70.. HLF.. (CBR, EFI)
48162-35070
LN5#, RN55.. DSL, TBO -- -- Discontinued
48162-35090
RN55.. 10T, HVY; LN56, RN75.. EFI, TD
48162-35110
RN6#
48162-35130
VZN6#
48161-35040
Spring, Torsion Bar, RH
48161-35070
48161-35090
48161-35110
RN6#
48161-35130
LN66, VZN6#
Last edited by ironhead; 10-25-2014 at 06:55 AM. Reason: All OEM torsion bar parts numbers and acronyms
mavenator
05-16-2016 03:49 PM
89fourrunner
02-17-2016 06:52 AM
justdifferentials
Just Differentials
09-08-2015 03:15 PM
justdifferentials
09-08-2015 03:13 PM
mavenator
08-13-2015 01:12 AM
Quick Reply: What torsion bars will fit?
