| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
What symptoms really warrant valve adjustment?
#2 (permalink) |
I guess a compression test would tell you if they were badly out of adjustment.
__________________
~Dale~ 93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift front, Alcan springs rear, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" Body Lift, 1.5" ball joint spacers, manual hubs, TJM T-17, Warn m8000. |
#3 (permalink) | |
Location: @ work somewhere between Walla Walla, WA and Lewiston, ID
There are no 'symptoms' of valves being out of adjustment- just about any performance issues caused by mal-adjusted valves could just as easily be attributed to ignition, induction or exhaust problems.
What may cause one pause for thought about the valves are engine performance issues that have had everything else BUT the valves checked: no one wants to take the engine apart. The valve-train is a mechanical wear system. They do wear and need to be checked periodically even when nothing else seems to be wrong. It is a gradual wear process and as such, do not receive the attention they should get until it's too late. I'd say check the valve clearance at least every 40,000-50,000 miles... and also anytime anything significant (more than an oil/fuel filter, pcv valve, or tune-up/spark plug change) is done to the engine. To wrap it up, the only symptom that requires a valve adjustment be performed is that the valve adjustments are out of spec. The important thing is to check them periodically.
__________________
Quote:
Insomnia: it's a way of life.
#4 (permalink) |
Loose valves are noisey
Tight valves cause rough idle and can lead to burnt valves. If you have it apart to reseal the valve covers you should absolutely check the clearances. If the clearances are in spec, there is no other reason to adjust them
__________________
Targetnut don't talk about it, just do it! Precision Import Service '93 2WD 22RE, Ported w/os valves, custom intake manifold, crane cam,Megasquirt, 295cc injctrs, Supra fuel pump, adj fuel pres reg, 70mm throttle, LCE header, V6 Taco cat, 14lb flywheel, Kevlar clutch, W58 and short shifter, 4.10 gears w/Truetrac, drop spindles and blocks, 245/50-16 Yokos on 16x8 wheels, 4WD fenders, bumper, and valence, skinned tailgate |
| Tags |
| adjust, adjustment, clearence, engine, idle, intake, ka24e, ruff, symptoms, tick, tight, time, valve, valves, wrong |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 3.0 Valve adjustment | CoedNaked | 95.5-2004 Tacomas & 96-2002 4Runners | 7 | 10-28-2009 06:38 AM |
| burnt valve symptoms | jay-q | 86-95 Trucks & 4Runners | 7 | 09-04-2009 12:26 PM |
| Valve Adjustment How Too... | skinnadoor | 86-95 Trucks & 4Runners | 4 | 07-23-2007 07:07 AM |
| 3.0 Valve adjustment | CoedNaked | 86-95 Trucks & 4Runners | 5 | 01-29-2007 08:43 PM |
| valve adjustment | yotarunner96 | 95.5-2004 Tacomas & 96-2002 4Runners | 7 | 03-09-2006 08:22 PM |
