What specific manual? Or where can I get info?
Old 10-14-2016, 10:09 AM
Diego toyota's Avatar
Greetings? My question is where can I, or what manual can I get information on cold start injectors and
cold start timing switch testing .I purchased the Haynes manual 92075 due to me having cold starts issues an cannot seem to find information on these topics in this manual.Can someone help. Thanks.
Old 10-14-2016, 10:36 AM
wyoming9's Avatar
Red face
Find a Hard copy of the Factory Service Manual for your Truck
Just what year are you working on Someone should have the information you want
The coil for the Cold Start injector can be open causing the Meter to show infinite resistance different meters display it in different ways
Pretty much the same depending on the year
Funny I had to go find my Copy of the Haynes Manual the same one you show The information you seek is in mine maybe they thought it was no longer of any use .
Old 10-14-2016, 11:45 AM
[QUOTE=wyoming9;52338593]Find a Hard copy of the Factory Service Manual for your Truck
Funny I had to go find my Copy of the Haynes Manual the same one you show The information you seek is in mine maybe they thought it was no longer of any use . I have a 91 22re. Can you tell me where you have that in the manual, may be I am not reading it correctly. I was looking in the trouble shoot section. Thanks Wyoming9.
Old 10-14-2016, 03:56 PM
wyoming9's Avatar
Red face
Now different editions of the same manual can be laid out different
It should be located in the Fuel and Exhaust Section
gives you thge info to test
Now my Copy is at least 15 years old if not older
Old 10-15-2016, 11:15 AM
Thanks Wyoming 9, I'll look through that section to see what I can find.
Old 10-15-2016, 05:09 PM
robertd33's Avatar
http://tacoma.site40.net/4Runner_90-.../local%20files
Old 10-15-2016, 05:29 PM
muddpigg's Avatar
Man someone liberate my hard copy on one of our last moves. Using digital copy sucks, can't make notes in margin. Think one of these days I'll print one out and piece it together for my rig. Front axle, late model intake, disc conversion kit, alt swap, 160 cam... Be nice to have it all in one place and to make notes.
Old 10-16-2016, 02:48 AM
wyoming9's Avatar
Red face
Maybe because I learned on Paper Manuals I just can`t relate to digital manuals
Maybe if I learned how to use 3 monitors at once which seems to be the trend these days
Old 10-16-2016, 04:20 AM
robertd33's Avatar
i printed it...
and i use 3 monitors...
Old 10-19-2016, 05:41 AM
Wyoming9,
It is 72 deg outside, an I decided to run some tests.
The cold start injector is reading 3.4 0hms.
The cold start injector switch Between STA-STJ is 80.6
Between STA- ground is reading 81.6 does these specs sounds correct. Thanks
Old 10-19-2016, 12:30 PM
wyoming9's Avatar
Red face
I would have to double Check the Cold Start Injector reading .
But the time switch looks within specs
surfishjoe
10-19-2016 03:57 PM
1994 3VZ-E 4Runner
10-17-2016 12:09 AM
Diego toyota
10-13-2016 02:50 AM
Ramiz09
10-12-2016 04:02 PM
pstallard
10-11-2016 04:51 PM
Quick Reply: What specific manual? Or where can I get info?
