what size tires?
Old 03-04-2009, 06:18 PM
durtyrunner94's Avatar
what size tires?
got a 5 inch custom built lift comin, already got 5:29 gears. wondering what size tires you can fit under 5 inches and whats the biggest i should go with 5:29s
Old 03-04-2009, 06:21 PM
abecedarian's Avatar
were it me, I'd use a 35" tire even if the gearing gave me a little more room.
Old 03-04-2009, 06:36 PM
well the 5:29s arent as low as i thought they would be but i do like to build em big but at the same time dont want it to be a dog seeing how im keeping the 3.0 in it. my thoughts were the 35 12.50 bfg m/ts. didnt know if i could or should go any bigger than that
Old 03-04-2009, 06:44 PM
EWAYota's Avatar
I'd stick with the 35's. You might still have a little pounding to do on the pinch welds. My 33's are starting to wear a bit, looking at 35's or maybe a 36 on 4" lift, and some trimming.
Old 03-04-2009, 06:52 PM
yeah thought about 36s but i would prolly need a little trimming also. do you know of anyone that makes a decent set of flares? the widest ones i found for a 94 runner were only 1.25 inches and i need 3.5 inches. i think those monkey ears look like hell and would rather find something that looked a little nicer.
Old 03-04-2009, 07:02 PM
depending on what you really need, you may try here:
http://www.toyotafiberglass.com/
I mean, why get flares if you can get fenders?
Old 03-04-2009, 07:05 PM
that is true. prolly a little more salty though
Old 03-04-2009, 08:32 PM
bigarms23's Avatar
37s if dd i would stay with 35s
Old 03-04-2009, 09:37 PM
what about 37s? not familiar with dd?
Old 03-04-2009, 09:54 PM
ffryno13's Avatar
i have 37s on my DD= daily driver. i also run a rear spool and 5.29s.[IMG][/IMG]
Old 03-04-2009, 10:32 PM
iamsuperbleeder's Avatar
damn man
at least it's not you DD with 37" boggers there's a few guys out here by me that run boggers on their everyday truck; I just don't get it...
Old 03-05-2009, 08:51 AM
thats pretty sick man. does it seem like it has enough power or is it doggy at all? i was told if you put 5:29s in and run 35s that would make it run pretty close to the stock rpm as if you just pulled off the lot with stock tires and gearing
Old 03-06-2009, 12:51 AM
ffryno13's Avatar
superbleeder: i d love to run boggers on the road but um i like going in straight lines. maybe after i rebuild all my suspension.
Old 03-13-2009, 02:08 AM
ffryno13's Avatar
there is another guy on here somewhere that has 37 boggers but idk if its his DD or not. i think that 37 s are closer and better then 35 s with 5.29s it makes your final drive gear just a bit taller so you can hold a gear longer. and i haven t really felt any doggyness i can hold 5th up hills for alot longer. oh yeah and i am a like 2600-2700 at 65mph
Old 03-13-2009, 06:45 PM
muddbogg21's Avatar
id go with 36's perfect size i run 33's on a 3" body lift and ive seen guys run 35's on a 3" body lift with little to no rub
Old 03-15-2009, 07:30 PM
ffryno13's Avatar
i am probably going to go to 38" toyos or something and shortened 1 tons.
justdifferentials
Just Differentials
08-30-2015 08:42 PM
justdifferentials
Just Differentials
08-15-2015 05:25 PM
Gravel Maker
RuffStuff
08-06-2015 04:27 PM
Gravel Maker
RuffStuff
07-27-2015 06:53 PM
Yotoder865
07-09-2015 07:51 PM
Quick Reply: what size tires?
