What is this plug?
I don't have a 3.0 anymore, but it sure looks like that could be it. Check out this link: http://www.toyota-4runner.org/classi...-location.html.
Welcome to Yotatech!
So u have to remove the throttle body to get to it or can it be just plugged in? I'm looking everywhere and can't locate that part u show sure wish I could I'm dying to get this girl right
You might have to remove the air intake hose from the throttle body, but probably not the entire throttle body(though it might be easier if you did). I can plug/unplug mine without even removing the hose(but yours might be more difficult).
If you can't find it right where it should be(underneath and just to the right of the throttle body), then maybe it's missing?
Yeah I pulled the intake hose off I think it's missing or buried I'm going to take it to a good mech to try and finish this thing up. The harness that I show in the pic is badly frayed, can it be replaced or is it part of the main harness? Also mudhippy is there anything else that should be done while I'm have the knock sensor/ wire done? Thanks for all the safe advice
Hey, you should help this guy out. Consider it a return favor...for me helping you.
https://www.yotatech.com/forums/f116...outing-265864/
Thanks mudhippy will do would be glad to help. Mine is going in the shop Friday to get a new wire pigtail I hope this gets mine on the road as a daily driver I'm gonna gamble on the sensor being ok seeing a they rarely go bad and it's unhooked now.
Well my mechanic has it tore down and the wire was missing. Mudhippy u were dead on like always. There was a bi metal temp switch in the back behind intake that was bad it had to be order from toy so it's gonna be Friday before she is buttoned up I hope I did right by not buying a new knock sensor but with the wire gone I'm hoping that's all it is
Well, I picked her up today and no check engine light is on fingers crossed. It is running pretty good I have overdrive now code 52 is a real pain. One problem I am still having is it has a slight wiggle or shake the trans feels fine I think it just needs the harness cleaned and fresh lube. Seems like I read where that cured another simLr issue on here. The thing use to drop oil like the Exxon Valde or whatever lol. Wish me luck
Blamalam
03-12-2022 07:34 AM
