what parts from 3.4 can i use on 3.0?
Old 11-27-2012, 09:58 PM
ricear1234's Avatar
picked up a 90 runner. Ran good for a couple of weeks. The fan blade (looked like a jet fanblade to me) exploded like a grenade. I hear that the fan clutch is dead. We have the opportunity to pick up a '97 T100 SR5 for $400.00 dollars. It has been sitting for four years because of a warped head or whatever was their problem at that time.
I need to know if the fan, fan clutch, radiator, air intake (just before the air filter) and/or ignition coil from the 3.4 can be used on the 3.0. I would really appreciate any help i can get with this. thanks
Old 11-27-2012, 10:17 PM
Staff
DeathCougar's Avatar
The ONLY part that will swap over is the Fan clutch. That's it.
T100 uses a much larger fan blade, wider radiator (Wider, not thicker), WAY longer air intake tube, and the 3.0 does not use the same type of ignition coil as the 3.4.
You cannot use anything except the fan clutch from the 3.4 setup.
Charecter1
11-06-2023 10:08 AM
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
TokyoD23
07-12-2015 06:01 AM
Roger Borba II
07-09-2015 05:05 PM
Cplmike
07-08-2015 08:47 PM
Quick Reply: what parts from 3.4 can i use on 3.0?
