What is this part?
Old 10-12-2008, 05:43 PM
dutchboy's Avatar
What is this part?
3VZ-E engine. Driver side under exhaust manifold. Leaks oil like Valdez.
What is the blasted part?
What does it do?
Is it replaceable?
Thank you
Dutch
Layin under the driver door,looking up and forward.
Layin under front bumper lookin up and back.
Old 10-12-2008, 05:47 PM
jloewenheim's Avatar
This is your oil cooler. If it is leaking Anti Freeze, then your hoses are bad (the hoses go to the block and the water pump). If it is leaking oil, the bolt gasket or o-ring may be bad. Pretty easy fix if you can get to the oil cooler. Just undo the bolt, and replace the gasket.
Hope this helps.
Old 10-12-2008, 05:49 PM
dutchboy's Avatar
Yeah,it's leaking oil pretty good and..in a mighty hard to get to location.
Thanx for your help. Mucho appreciated!
Dutch
Old 10-12-2008, 06:01 PM
i just did mine while the engine was out of the truck (had to do a rebuild), but i am guessing that you may be able to access that by taking off the left tire. If not, it is just the bolt in the center of the cooler, you pic looks like you have easy access to that.
GFL my friend.
Old 10-12-2008, 06:19 PM
project91's Avatar
Toyota has the o-rings...the parts stores do not..I had the same issue..there are three o-rings in the set..run you about 12 bucks..not too bad..but it is an expensive set of rubber o-rings!
Old 10-12-2008, 06:29 PM
jason191918's Avatar
I just did it w/ the engine in the bay...but I have a 3" BL. Not the worst job in the world, but I could not find the parts at NAPA or carquest, so I found them at http://www.trademotion.com/partlocat...?siteid=214074
If you enter your VIN here, they guarantee the right parts.
OEM Catalog
WASHER, SEAL 1 $3.11 $0.00 $3.11
Status: Sent
OEM Catalog
GASKET, OIL COOLER 1 $0.84 $0.00 $0.84
Status: Sent
OEM Catalog
RING, O 1 $3.76 $0.00 $3.76
Status: Sent
Sub Total $7.71
Tax $0.00
Shipping $6.00
Handling Fee $0.00
Total $13.71
You need the 3 gaskets shown at the bottom here. Enter your VIN to be positive on the part number.
http://www.toyodiy.com/parts/p_U_199...MGEA_1503.html
Old 10-12-2008, 06:31 PM
dutchboy's Avatar
Thanx!
Not too bad on price. Now I just gotta buy some bands aids for the knuckle busting adventure to come.
Old 10-12-2008, 06:34 PM
Maybe a few beers too!
05-20-2016 10:27 AM
88sasturbotoy
08-11-2015 01:56 AM
Fundy Rider
07-16-2015 01:35 AM
akaphilly
07-09-2015 02:34 PM
Quick Reply: What is this part?
