What Oil to use for Lubricating Valves?
Old 09-30-2009, 06:33 AM
luddite20's Avatar
Just did a valve job on my cylinder head, and am wondering if there is a best lubricant to use for the valves in the guides? What oil would be bad? Why? Could 3 in 1 work, or would it not hold up to the temperature? Thoughts?
Old 09-30-2009, 06:38 AM
Lumpy's Avatar
I used a Permatex Assembly Lube when I did my HG. I used this on the rockers and cam bearings.
http://www.google.com/products?hl=en...title&resnum=1
Old 09-30-2009, 09:11 AM
TNRabbit's Avatar
The best I've found is to slather it with STP Oil Treatment~
Old 09-30-2009, 06:13 PM
InternetRoadkill's Avatar
A good assembly lube and some GM E.O.S additive.
Old 09-30-2009, 06:17 PM
Lumpy's Avatar
Have you tried KY I hear the strawberry works well!!!
Old 09-30-2009, 08:28 PM
abecedarian's Avatar
/me lolz @ lumpy... and all the replies.
luddite20: puttin up flame bait? ... or you don't know how engines work?
either way, you're not looking good here.... If you know how to lap valves, you know what to do and what needs done... and if you didn't know what to do, you read enough to learn what to ask about so...
... meh.
ball >
ur court >
bounce > ?
smthwsn357
12-04-2023 02:08 AM
calderp
Engine Swaps
08-16-2016 05:15 PM
09-04-2015 09:27 AM
irritech
07-27-2015 05:15 PM
calderp
07-27-2015 09:58 AM
Quick Reply: What Oil to use for Lubricating Valves?
