what lift for 35´s
Old 07-31-2008, 04:10 PM
4runnerguy's Avatar
what lift for 35´s
ok i have a 1991 4runner. im thinking of puting a 2 inch body lift and 2 inch suspention, and i have 15x10 4 inch back spacing rims would it work.
Thanks
JOSH
Old 07-31-2008, 04:22 PM
4runnerguy's Avatar
bump bump
Old 07-31-2008, 04:52 PM
Jay351's Avatar
No. Not without considerable trimming/pounding.
Old 07-31-2008, 05:07 PM
85toy's Avatar
nope wont work needs more lift and alot of fender trimming. also you need a sas why do you want 35s if you cant even beat on it without destroying your ifs
Old 07-31-2008, 05:09 PM
UCDBunsen's Avatar
It will work only if you don't mind a couple of messed up body panels.
Old 07-31-2008, 05:16 PM
4banginRunner's Avatar
i ran 35x12.5s on 15x10s on my old 90 4runner
that had a 3" body lift, 2" t-bar crank, and 2" spacers in the back
the front still rubbed pretty bad
Old 07-31-2008, 05:59 PM
Jay351's Avatar
Yep, for minor trimming you will need around 6-7" of lift.. with IFS that is and that wide wheel you got..
Old 07-31-2008, 07:01 PM
CC_yota's Avatar
What about this guy?
https://www.yotatech.com/forums/f116...3rd-gen-74326/
Unfortunately the pics no longer work.
He was running 35x10.50 with 0 lift, and there's a guy over on UY, I believe, that is running 35x12.50 with very little lift but a lot of fender trimming and firewall clearancing.
The problem you're going to run into is that you can't trim a whole lot out of the rear on 2nd gen 4Runners because of the rear door. And steering components are going to bend or break. The suspension is up to the task but the steering may not be.
Needing a SFA for 35's is bs.
Old 07-31-2008, 07:44 PM
Mic09dcsm's Avatar
Hey 4banginRunner what was the backspacing on those 10 inch wide rims?
Old 07-31-2008, 07:59 PM
Noltz's Avatar
3" body, no suspension, some thumping of the firewall. Still rubs... I don't care. I play in the mud with it.
Old 07-31-2008, 11:11 PM
bob200587's Avatar
fail
Old 08-01-2008, 03:02 AM
4" BS i believe not 100% sure
Old 08-01-2008, 04:51 AM
WFO
WFO's Avatar
My buddy has 35x15.50s on 2" BS wheels on his 4Runner with only a 4" lift. They rub but not bad. And those tires stick waaay out.
Old 08-01-2008, 07:12 AM
camo31_10.50's Avatar
*HIJACK* hey Noltz..what kind of tires are those..i see super sport on the side..but who makes em?????
Old 08-01-2008, 09:08 AM
85toy's Avatar
well i havnt seen those pics but im sure it looks a bit funny, what im saying is all you would be able to do is drive around the street, try flexing out and see what happens. also the large tires will mess up the stock ifs.
Old 08-01-2008, 06:15 PM
4runnerguy's Avatar
ok so i guess im goin to stick with 33 x 12.50
Old 08-01-2008, 06:39 PM
EWAYota's Avatar
4" suspension, 2-3" body. A member along time back on here ran that on his 4runner.
Old 08-01-2008, 08:11 PM
Mic09dcsm's Avatar
When my 35's get here we'll see.
I have:
-4Crawler BJ spacers (1.5")
-T-bar crank (don't remember stock height, just cranked)
-2 inch BL
-2 inch blocks
-3 inch Downey lift springs/u-bolt flip kit
My front fenders are sitting at 41.5" in the front and 42.875" in the rear.
Old 08-01-2008, 08:19 PM
eightnine's Avatar
those are the same tires that i have on my truck but in a 35, they're called Super Sport Radials H/T and they are a cheapo walmart brand ripoff of BFGs old mud terrains. They are decent and I only got them for 40$ each at walmart. Unfortunetly they are now discontinued.
Old 08-01-2008, 09:02 PM
CC_yota's Avatar
Try flexing out with 31's not much more happens and he never said he was going to do more than drive it on the street.
If he does wheel it and breaks , so what? That's part of the sport. An extra drag link, a spare cv, and maybe an idler arm and he would be good.
Don't get me wrong I like SAS'ed rigs and would like to swap mine but not until I wheel the piss out of the IFS. I just get tired of the "You gotta do this before you can do that" bull.
And, actually I think it looks pretty good.
:Hillbill:
Quick Reply: what lift for 35´s
