What kind of transmission is this?
does anyone know what kind of transmission this is.. I am told it is out of a 1990 toyota extra cab se. do not know the motor size or have the vin or anything but these pictures.. also is it possible to put a transfer case onto this and what would need to be done to do this.. thanks
well i have a g52 tranny and w56 tranny that are no good sittin in my shop as well as a transfer case for both of them so top and forward so i didnt know if maybe the back case would change out for one of those two? i am not really familar with how a transmission works though so i have no actual idea
Even if i already have a w56 out of a 4wd with no good gears? is it only the extension housing that would have to be changed over to a transfer adapter or is there more to it than that? its basically what i would like to know
Oh, didn't check all of the posts
The W 2wd and 4wd transmissions are the same, just with a different rear housing. Although the actual gear ratios may be slightly different.
If you already have a good extension housing gathering dust, by all means use it on the 2wd transmission.
ok i just wanted to clarify that it would work with one of my transfer adapters. but can someone confirm this is a w55 or w56 or whatever it would be since im payin for it i want it to all fit together when i get it.
i dont have it... i am going to buy it.. but if its a g series then would the g52 transfer adapter work also? because i got one of them layin around too..
well so far its going ok.. all the gears are going to have to be switched over from the 2wd output shaft to the 4wd output shaft since most gears on the 4wd shaft were ground to nothing and of course it has to be diffrent gear sets so this is going to take me a little but of time for my first rebuild. but the extension housing off and putting the transfer adapter on it all bolts up so thats a good sign.. just to get all the internals switched from one shaft to the other and put back together.. i will post some pics later on
Dennisx2
08-04-2015 01:26 PM
