What are freeze plugs?
yeah i had 3-8" of ice on the carpet, chipped it off with a screwdriver, but back on topic. Frost plugs suck to get out, so good luck your going to need it.
lol. I hate the carpet ice too. I never had that problem with my '93, but since the carpet was ripped in the 4runner right in front of the clutch pedal, ice built up there. Also, my sister's Heep Liberty got some massive ice in front of the clutch and gas pedals.
A freeze plug is there to allow the removal of the casting sand from when the engine block was originally cast. They won't stop block damage from a frozen water jacket.
#26
i just went up and checked the the truck out again. none of the freeze plugs on the sides of the block look popped or leaking. i couldnt see the one at the back but didnt look like there was coolent at the back anywhere.the radiator is empty i only had a 600 ml of water so didnt have aenough to fill it up or anything.
#27
To remove them, try to knock it sideways and pull it out. Pushing it all the way into the block will make things a lot harder.
#28
Exactly right. Fill er up with water and see if she'll crank up. Actually, you wouldn't have to start it up. Start looking because if one is busted, you'll know it real soon. If you do find one busted, you might as well plan on pulling the engine and give that block a good check also. Replace ALL of the freeze plugs while you got it out. I'm like the others, even if it's busted, you could still part it out for more than you paid for it.
#29
Well, they 'can' prevent damage to the block in case the block freezes, but typically only if the antifreeze is in good condition and at the proper mixture since the coolant will tend to freeze slower than depleted coolant / straight water and will slush before freezing. The freezing is most likely to occur at the point of highest thermal transfer which happens to be the thin, bare brass plugs, not the heavier iron engine block.
but like said, fill it with water and go leak hunting... take some starting fluid out to see if you can get it running. you can find used engines for a few hundred to a thousand, rebuild that one for the same, maybe less, or as mentioned part it out. you could probably get a few hundred each for the frame, trans, and a little less for the other parts like ECU, interior, etc. and make your money back plus some... or even make a hybrid project- combine the two trucks so you have the xtra cab with your std cab's engine, etc. and then sell the left-overs.
#30
But, seriously. If you somehow knew that all it needed was a new freeze plug or two, then this might be worth it. But you don't know that. If a freeze plug has been pushed out, it's sure possible it cracked part of the block first. And it might be a fine crack; one that you wouldn't find until you put 50 hours and $1800 into a rebuild. And the block isn't the only thing you have to think about; every part of the truck has been sitting around slowly rusting away.
The plus side is that there's a limit to how bad you can screw up. If you've got the time and some money, this is a better vehicle to learn engine rebuilding than your 2008. Just be prepared to for a long journey.
#32
So maybe I don't live in the right place, where engines freeze, but statistics are statistics and anyone can make them say what they want. And considering I've said that sometimes they don't work, then that means they don't work all the time.
#33
i hooked the jumper cables up to it and it wouldnt turn over. i could turn the motor by hand so i know its not seized. the clutch is sticky i put it to the floor and had to pry it back up with my foot. its been sitting since atleast 07 i'd say when the mvi ran out, so theres probably lots of stuff seized up. i looked at all the freeze plugs except for the back one and felt them none seemed rotten or popped out so i'd have to fill it with water try to find the leak. the box is shot the frames good but getting scaley from sitting.cab needs work interior is really dirty. starting to think its prob gonna need more work than i have time for right now.it would be a good rig for parts if i end finding an ext cab down the road.
#34
Many times jumper cables are not enough. You probably need to put another battery in it (a fully charged one) and try it again. The battery that's in it no doubt has been frozen and is toast.
Tacoma1313
08-17-2015 05:44 PM
