What does this vacuum switch do?
Old 12-04-2014, 07:11 AM
92DLX's Avatar
A rodent chewed the wires to part number 90910-12084, the vacuum switch assembly on top of the valve cover on my 22re. I'm wondering what this part does and if I can make a 1500 mile road trip without it.
Mid photo, brownish plastic, chewed wires.
I leave early next week and so this is a last minute snafu that I'm hoping can wait to be fixed on the other side.
What do you all think?
Old 12-04-2014, 07:14 AM
92DLX's Avatar
P.S.
Truck seems to be running fine without it for now.
Old 12-04-2014, 07:37 AM
scope103's Avatar
PAIR vsv http://personal.utulsa.edu/~nathan-b...20pulsedse.pdf
It significantly reduces emissions when working, but you can still drive it as is.
Old 12-04-2014, 10:07 PM
Punchy's Avatar
Blue one is PAIR, Red one is Fuel pressure up.
Can run with out ether.
Old 12-05-2014, 12:19 AM
jennygirl's Avatar
Judging by the photo, it seems that you are talking about the FPU VSV on the right- with the munched wires.
It's pretty common for people to delete that VSV completely and route the vac line that connects to it from the triple adapter in the plenum straight to the fuel pressure regulator vac input. Then remove the other vac lines that go to it and cap.
The only issue you might see (but probably won't) is a hot start issue... That is what the FPU VSV is for. Most people who remove it report no issues, though.
Blamalam
03-12-2022 07:34 AM
justdifferentials
Just Differentials
09-17-2015 06:14 PM
rjtrials
08-06-2015 07:25 PM
greenbuggy
3.4 Swaps
07-23-2015 11:51 AM
TokyoD23
07-12-2015 06:01 AM
Quick Reply: What does this vacuum switch do?
