what does this code for mycheck engine light mean?
I have been having an extremly rough idle in my 95 4runner and the check engine light coming on and off. So i pulled the codes and the sequence of the check engine light flashing was 2 pause 5 pause 5 pause 2. Does anyone know where i can go to figure out what this means, thank you
You have two codes there:
25- O2 sensor reading a lean mixture
52- knock sensor
http://www.ncttora.com/fsm/1990-1995...e/diagnosi.pdf
Just assuming you have the 3vze, but either way, its the same for a 22re or 3vze.
52- knock sensor
06-01-2021 01:51 PM
steve miller
10-10-2015 01:40 AM
Jnkml
07-06-2015 01:20 PM
FS[SouthEast]: 1st Gen 4Runner Slider Window, Driver Side
coryc85
07-06-2015 04:07 AM
