| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
What to do on a recent purchased 91 4runner
#2 (permalink) |
What else should you do? Post pictures! You should share the toyota glory, its not nice to hog all of it for your self.
#4 (permalink) |
22re or 3vze?
__________________
'95 4runner|22re|5spd|130K miles|ISR| 2" BL| 31x10.5 | CompuStar Auto-start| two 170mm LightForce|anti-sway bars removed f/r|Warn manual hubs|ADD bypassed|Diff breather extensions|XLPerformance muffler '88 4runner|22re|5spd|206K miles|Sold '93 single cab|22re|5spd|150K miles|Sold| Pro IFS |
#6 (permalink) |
Anyone?
__________________
'91 4Runner 3VZE manual, 32" tires. Lots of work and questions for you all! |
#7 (permalink) |
you could really open a tin of worms with a question like that. You could just leave it alone now, or you can do a million things to it. I put a v8 in mine and things just didn't stop after that, in fact the list just keeps growing. My little 4 Runner is on its 3rd rebuild mow.
#8 (permalink) |
How many miles? I would check out the condition of the timing belt. change the oil, coolant and drive-train fluids.
__________________
#9 (permalink) | |
Quote:
Mods are for after its running good lol. Minus a couple little things here and there. Mainly looking for service work that i need to check though.
__________________
#10 (permalink) |
Check the cat and 02 them are both big factor's in the power and fuel mileage department , check compression on all cylinders see if you are going to need a set of head gaskets
plugs and wires should be factory 3.0 don't work well with other then Toyota plugs and wires most of the time, rotor and cap, replace the fuel filter run Sea foam through the motor to clean up the carbon build up on the valve train and pour some in the fuel tank to clean the injectors , timing belt, water pump and tensioners as a just so you know they have been done safety measure
__________________
1990 4 runner 5 Speed Pro Comp Stage II 4" Lift 6" coils rear Aussie Locker front 5.29's Front And Rear 35 x 12.5 x 15 MT's Micky Thompson Classic II Wheels Super Charged 3.4 on the way 1993 SAS 4runner 22re 5 speed 4" front 5"rear 5.29's 35 x 12.5 BFG KM'S Dick cepek DC 1's 88 stock 4runner 3.0 auto for now 1955 Harley Davidson Springer Stock 1955 Hardtail Frame 4 Speed Kick Start Only 1998 Harley Custom Dresser 107 rwhp 139 ft.lbs.trq. Last edited by olharleyman; 11-09-2009 at 10:58 PM. |
#11 (permalink) |
drive-train fluids- Transmission, T-case and differentials. Grease the u-joints and ball-joints(if applicable)
__________________
#12 (permalink) | |
Quote:
__________________
#13 (permalink) |
Do a seafoam treatment trick,and make sure inside of throttle body/ air intake where the butterfly doors are, are clean and easy to move.
#14 (permalink) |
x3 on the seafoam
and there is a bushing on your shifter that has probably worn down and that is why u are getting play The blue thing
__________________
• 91 4runner • 22re • 1" BL • sliders (soon) |
#15 (permalink) | |
Quote:
__________________
My Truck: 1994 Pickup 4x2 Base Model 114k miles SunPro Tach, Smittybilt Rear Bumper , 3" 4Crawler Lift, 15X8 Outlaw II's and bigger tires on there soon Some Day: Bucket Seats and Armor |
#16 (permalink) |
um kinda that will help but that one is for the transfer case
this is the seat (the blue is for transfer case) http://www.marlincrawler.com/transmi...-shifter-seats And this is the bushing i was talking about (watch the video on the bottom) http://www.marlincrawler.com/transmi...shifter-socket if u replace both it will fix that problem
__________________
• 91 4runner • 22re • 1" BL • sliders (soon) Last edited by 4Yoter; 11-11-2009 at 11:59 PM. |
#17 (permalink) |
suspension
__________________
the story is old, i know, but it goes on. . . (:'95 4Runner: 3VZE-Rebuilt :5-spd.man: ISR'd:)
#18 (permalink) | |
Quote:
__________________
| Tags |
| 4runner, 91, belt, changing, cost, installation, play, rotor, shifter, timing |
