what do I need to remove to weld?
Well, im gonna weld a piece of my frame back onto the car, and I know i need to remove stuff.
What exactly do I need to remove?
Alternator, battery?
thanks
thanks
i welded on my frame and didnt disconnect anything, but to be safe you could just disconnect the battery cables. i think if you have a winch you need to disconnect it. i heard you can fry them if you weld with them all hooked up, just my opinion
i heard from somewhere u need to disconnect the alternator... i don't really feel like it so i just wanna make sure.
The battery is way easy to disconnect.
What about my circuits?
I just got done welding on the body today, I had a door open and watched the lights when I threw an arc just to see what happened.
The answer (not surprisingly) is nothing. And it started up and drove just fine, radio worked too.
Just make sure you put the ground close to where the arc will be (and on the same piece of metal) and you should be fine.
everyone just covered most everyting possible-
place the ground electrode as close to the weld as possible
disconnect the battery (at least the positive, and keep it insulated from the rest of the vehicle)
you should be fine.
you should be fine.
disconnect both terminals on the batt.... and ground close to what ur welding.. some newer vehicles may have more they want disconected.. might possibly be in the service manual or under the hood.. never really looked before.
Jcrawl94
10
10-24-2015 04:34 PM
crashburnoveride
07-10-2015 06:39 AM
