What is the difference between 2 pinoin and 4 pinion?
Old 07-24-2010, 03:13 PM
toyotanick's Avatar
ok hear me out.
both 4cylinders and v6 model pickups come with a 2"pinion" carrier but when ordering gears they ask you if its v6 or 4cylinder not if its 2 pinion or 4 pinion.
so does this mean that the 4cylinder takes a different gear?
also does this mean that no matter what, even though the v6 is a 2pinion carrier, it is still stronger than the 4cylinder 2 pinion even though they look identical.
one more thing. if i were to weld the v6 2pinion carrier will it be as strong as the 4pinion carrier welded, im sure it wont but i doesn hurt to ask.
im sorry for being a pain in the ass but i want to get my stuff straight and do it as right as i can the first time.
Old 07-24-2010, 06:38 PM
toyotanick's Avatar
come on guys, i know one of you brilliant individuals knows!
Old 07-24-2010, 06:43 PM
waskillywabbit's Avatar
Have you read Erik Bs differential page?
http://home.4x4wire.com/erik/diffs/
Old 07-24-2010, 06:55 PM
toyotanick's Avatar
no i didnt not and thank you but that does not answer my questions.
Old 07-24-2010, 06:57 PM
Then READ the information on the link please.
Old 07-24-2010, 07:15 PM
toyotanick's Avatar
ok its a stronger housing... but are the spider gears stronger as well?
and would a spool or welded diff level the playing field to where i dont have to worry about finding a v6 and or diff with 4 ribs on it. because thats really all i am asking. will a welded diff basically make the 2spiders or 4 spiders irrelevant, as long as its a r ribbed v6 case
Old 07-24-2010, 07:18 PM
Weld up what you got and quit worrying about finding something else. 4 cyl 6 cyl diffs, never seen any significant difference. Only benefit is if you put a high pinion in the front.
justdifferentials
Just Differentials
14
09-24-2017 08:32 PM
Jcrawl94
10
10-24-2015 04:34 PM
justdifferentials
Just Differentials
08-15-2015 05:25 PM
trailgoat
08-13-2015 05:54 PM
kirkrunner
07-27-2015 07:59 PM
Quick Reply: What is the difference between 2 pinoin and 4 pinion?
