What clusters are compatible with my truck
I have a 94 22RE with a base model cluster. I would like to install a SR5 cluster. I would like to know what clusters are compatible with my truck. I saw one in a early model tacoma at a yard, would that one work even though its from a different generation. thanks
In order to simplify things at the assembly plant, most all of the same models were made compatible. When models change however, wiring changes (a little) so you would just have to compare the connectors on the back of them both (and wire colors).
would one out of a v6 one work. or out of a early model tacoma
no the tach wont work right
also disconnect your oil sending unit or you will blow the gauge
mine in the 84 is toast
buy the right oil sender from a parts store
