What causes the "brake" light to stay on? - YotaTech Forums
Go Back   >
LinkBack Thread Tools Search this Thread
Old 02-20-2006, 02:32 PM   #1
fierohink's Avatar
Question What causes the "brake" light to stay on?
I know it comes on when you pull the parking brake. And it comes on when the fluid gets low. But mine stays on and neither of those are the problem. What else makes it come on?
fierohink is offline   Reply With Quote
Old 02-20-2006, 02:43 PM   #2
surf4runner's Avatar
failure of the parking brake switch itself?
have you tried pushing the handle in hard or wigglin it around?
surf4runner is offline   Reply With Quote
Old 02-20-2006, 02:44 PM   #3
Tacoma Dude's Avatar
Tacoma Dude is offline   Reply With Quote
Old 02-20-2006, 04:23 PM   #4
Likely the fluid sensor in the reservoir is sinking cuz it's worn out. Disconnect the wires from the cap and see if it stops.
Mike in AR
I chased that one for a long time.
regularguy412 is offline   Reply With Quote
Old 02-24-2006, 07:12 AM   #5
86SR522REEFI's Avatar
Quote:
Mike in AR
Or just buy a new one. Check your fluid level in the brake fluid Resevoir and make sure that the park brake is all the way in. Just cutting the wire off of something that could save your life sounds like a real bad idea.
86SR522REEFI is offline   Reply With Quote
Old 02-24-2006, 08:54 AM   #6
rchavis's Avatar
I just brought one of those caps. They are between $90.00 and $100.00 depending on the dealer. Part number 84460-35050, Switch assy.
Might be able to find a used one, however it is an electrical part. Hope this helps.
rchavis is offline   Reply With Quote
Old 02-24-2006, 08:55 AM   #7
My brake light comes on occassionally...I traced it to the switch behind the parking brake handle. If I jiggle the brake handle the light usually goes out. The switch is not being fully depressed probably due to a weakened spring on the brake cable. There is a spring on the cable near the rear axle. There may be a way to tighten up the slack in the cable which probably would help too.
93Toyota PU is offline   Reply With Quote
Old 02-24-2006, 10:40 AM   #8
adjust the rear brakes first then adjust the slack in the cable. lubrication helps too
Old 02-24-2006, 10:44 AM   #9
Jeffires's Avatar
Quote:
...and even if that doesn't work, wiggle the handle and push it hard when you release the brake. My roommate's Tacoma did this.
Jeffires is offline   Reply With Quote
Old 02-24-2006, 11:09 AM   #10
I had the same problem. My mechanic told/showed me that I needed new rotors and pads. $187.00 later the problem went away.
Mako
20mako1975 is offline   Reply With Quote
Old 02-24-2006, 12:42 PM   #11
I changed out the park brake light switch and it didnt cure the problem, although, it could well be just that. There's no wire cutting involved with the fluid reservoir gauge. The cap that holds the donut has a plug on the end. Just a matter of unplugging it to TEST it and see if it is, in fact, the culprit. If that's the case, then one can choose to replace the cap / gauge.
I've noticed no decrease in any braking effectivness with the float (gauge) unplugged.
Mike in AR
Old 02-24-2006, 07:30 PM   #12
tc
tc's Avatar
Mine did that because of a frozen/locked up caliper.
tc is offline   Reply With Quote
Old 02-24-2006, 09:36 PM   #13
DudeBud's Avatar
sometimes unpluging the master cylinder cap for a temp fix works
DudeBud is offline   Reply With Quote
Brake lights staying on/stuck fountain 86-95 Trucks & 4Runners 5 12-31-2015 07:08 AM
FS[PacNorWest]: Toyota Inclinometer/Altimeter AkitaDog Misc Stuff (Vehicle Related) 12 09-01-2015 09:05 AM
93 toyota pickup 4wd dash light stays on ViperTT 86-95 Trucks & 4Runners 8 08-14-2015 06:27 AM
93 Toyota 4x4 22re - Strange Electrical Problem(s) PopsDad1 General Electrical & Lighting Related Topics 0 07-30-2015 03:21 PM
88 pick up battery light on mluz013 Newbie Tech Section 1 07-24-2015 01:31 PM
Tags
8446035050, adjust, brake, emergency, fix, light, lights, mod, on, spring, stay, stop, switch, tacoma, time
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
