YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 07-24-2008, 04:05 PM   #1 (permalink)
MIKEMOKAS's Avatar
Send a message via AIM to MIKEMOKAS
What are all the parts included in the 4in bracket lifts?
hey guys.
i think that im actually ready to bolt everything up to my toyota tonight, and i just wanted to clarify a few things before i get greasy.
this was in the pile of parts that i bought a while back... (some of you might remember the thread...) what is it, where does it go?
and heres everything else. are their any other misc. brackets that im missing?
i think ill only be using the crossmember on the right, the guy before me had to make the one on the left when he used both lifts together. (3.5in rancho and 4in procomp..) please let me know about the misterious crossmember asap!
thanks, and wish me luck!
__________________
My MYSPACE - You know you want to request me.
DD: '91 Toyota Pickup SR5 3.0L 4x4 5-Speed. Marlin Shifter Seat And Bushing, 31in. BFG ATs, Alum. Wheels, K&N, 4in ProComp Stage I Susp. lift... 3.5in rancho ready to install.
leaky valve covers!!!!!!!!!!
'91 Toyota 4Runner SR5 3.0, auto. SOLD. <-- You Will Be Missed! 05.07.08 6:00pm.
'95 Chevy S10 LS 2.2L I4 2x4 Auto, 31in. BFG M/T's on AR Outlaw II's, 3in Susp. Lift... 3.5in fabtech spindles ready to be installed.
MIKEMOKAS is offline
Sponsored Links
To remove this ad, register today!
Old 07-24-2008, 04:14 PM   #2 (permalink)
abecedarian's Avatar
okay... you're missing some things... in particular the driver's side bushing and drop mount for the front differential housing. probably more, but my mind is pulling an OJ and didn't do it.
__________________
Quote:
Originally Posted by SwampThing View Post
I'm really starting to hate being bent over all the time.
Quote:
Originally Posted by BoostinChick View Post
It's ok I don't have boobs either Allan.
Quote:
Originally Posted by YotaTech Moderators
What do you mean we have a chat room? What's the URL?
Oh, here it is:
http://www.yotatech.com/misc.php?do=flashchat
abecedarian is offline
Old 07-24-2008, 04:15 PM   #3 (permalink)
I don't see a second set of lower control arm mounting bolts - you need them to bolt the drop bracked to the old lower arm mounts.
__________________
Oh, here it is:
Old 07-24-2008, 04:16 PM   #4 (permalink)
I don't see the bolt used to bolt the existing steering knuckle to the drop brackets (where the old balljoint used to connect to the knuckle).
__________________
Oh, here it is:
Old 07-24-2008, 04:18 PM   #5 (permalink)
olharleyman's Avatar
The one on the right go's to the front if you look at the stock one thats on there you will see the mount on the end is for your front third to bolt into.
__________________
1990 4 runner 5 Speed
Pro Comp Stage II 4" Lift Kit custom 6" coils rear
lock right #1620 Rear
Aussie Locker #xd-27527 front
5.29's Front And Rear
35 x 12.5 x 15 B.F.Goodrich KO's Micky Thompson Classic II Wheels
1955 Harley Davidson Springer
Stock 1955 Hardtail Frame
4 Speed
Kick Start Only
Streached 5.5 gal. tanks
16" Ape Hangers
3" open primary
"Three People Can Keep A Secret If Two Peolpe Are Dead"
Benjamin Franklin
olharleyman is offline
Old 07-24-2008, 04:55 PM   #6 (permalink)
904_runner's Avatar
you also need tapered sleeves for the spindle extensions.
brake line extension brackets.
among a butt load of bolts that are missing
__________________
-Mike
1990 4runner SR5, 3.0 with 253K, 5-speed, 4.56 gears, warn premium hubs, Hella 500's, Rancho 9000's, 33X12.50's trxus mt's, rear lock right, 4" trailmaster lift with lc coils in rear, panhard drop bracket
One Day: 3.4 swap and SAS!
www.myspace.com/222948743
904_runner is offline
Old 07-24-2008, 07:22 PM   #7 (permalink)
Cyberman's Avatar
Brackets for dropping the sway bar and the bump stops are missing, as well as the LSPV extension (if you have the LSPV).
Cyberman is offline
Old 07-24-2008, 10:15 PM   #8 (permalink)
MIKEMOKAS's Avatar
wow, thanks for all the replys!
i do have all of the bolts to do the job, and their all new. i still have to figure something out for the bumpstop extensions, and instead of dropping the sway bar im going to get longer bolts and sleeves, and leave the sway bar in the stock location.
Quote:
what is this bushing and drop mount you speak of? can you describe a little more clearly, please.
Quote:
does anyone have any pictures on hand of the bumpstop/ lspv extensions on your trucks? they would help alot! or even if someone could describe them to me. ill be doing all the work in an alright equiped shop, so ill have to make the brake extensions, lspv extensions, and bumpstop extensions myself.
i went over their tonight and dropped off all of the lift parts and the box of bolts that i have. surgery begins at 2:00pm tomorrow!
thanks for any help guys!!!
__________________
Old 07-24-2008, 10:18 PM   #9 (permalink)
904_runner's Avatar
The lsvp bracket is just a bracket that extends off the axle and pushes the lsvp trigger (whatever its called) up. Bracket should be the same amount as the lift in the rear.
Let me see if i can find a picture of the diff brackets.
__________________
-Mike
Old 07-24-2008, 10:21 PM   #10 (permalink)
904_runner's Avatar
Here is a link to the trailmaster installation instructions.
http://www.trailmastersuspension.com...ns/TP49_50.pdf
Make sure you have those tapered sleeves! I had to order some, took a week
__________________
-Mike
Old 07-24-2008, 11:04 PM   #11 (permalink)
MIKEMOKAS's Avatar
damn, i dont think i have any of the stuff to drop the front diff. bummer.
what is the exact job of the tapered sleeves? to center the origional hole that the balljoint goes into?
dont have them either.
bump stop, swaybar, and lspv brackets are going to be a cakewalk. the diff is only holding me up now. hopefully i can throw something together.
thanks again!
post up some advice/ ideas if anybody has any!
__________________
Old 07-25-2008, 08:58 AM   #12 (permalink)
MIKEMOKAS's Avatar
turns out that theirs supposed to be 3 different front diff drop down brackets. i wonder exactly how long thos brackets are? because i could use the diff drop brackets out of my rancho kit.. i just dont know exactly how much i neeed to drop the diff. is it EXACTLY 4in? i think so.
this would be the "center" one.
and this would be the drivers side
any thoughts?
thanks!
__________________
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
are bracket lifts a good idea? 88-surf 86-95 Trucks & 4Runners 8 10-11-2007 03:50 PM
WTB: 4in Lift Kit MUDN4R Items Wanted 0 07-15-2007 09:22 AM
90 toyota 4in lift w/ 33's npreo1 Offroad Tech 16 06-22-2007 02:28 PM
Need pictures of Cheap IFS lifts. Not the parts but the truck! JamesD Offroad Tech 23 11-10-2005 05:05 PM
Bracket lifts??? 01Mossy Oak edition Offroad Tech 2 09-05-2004 05:47 PM
Advertise on YotaTech.com
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
