What is this?
The pipe you are pointing to is a coolant fitting. Above where you art pointing is where your EGR is blocked off. This could be causing your surging idle by creating a vacuum leak with that filter on top of your valve cover. I would reconnect your egr hose and see if that helps your idle.
As for the coolant hose, try heating it with a heat gun and twisting gently.
They tend to stick if not removed in years.
A couple years ago I bought an entire 22re efi intake off craigs list and its really come in handy for spare parts.
