Welded Diff
Old 03-08-2010, 04:49 PM
DanStew's Avatar
Welded Diff
I just got to thinking. I have a welded diff and I want to change it to open or add a lockrite. BUT am I going to be able to remove welded spiders? I havnt been into a diff that has been welded but I know how to weld the gears together. I am thinking it maybe too much of a bear to get the spiders out. Am I thinking correct? Or will they come out in one large chunk.
Old 03-08-2010, 05:12 PM
akaphilly's Avatar
a welded diff is welded for life, the only thing you could do is get a full detroit or an arb.. i might have 1 i could sell if your interested cheap.... an open carrier that is.. edit
Old 03-08-2010, 06:11 PM
Junkers88's Avatar
Yeah once a diff is "Lincoln Locked" it's that way for life. Depending on what gears you have in it it might be better to buy a different diff and have the gears swapped or get a different diff and build it the way you want it.
What gears are in it now?
You might be able to sell the welded one to someone with a dedicated trail rig and make a small amount of money for your next diff.
Old 03-08-2010, 06:14 PM
DanStew's Avatar
it is a 4.88 diff. I have to go and count the ribs and see if it is a V6. It might just be a spool, but my gut instinct and knowing how somethings on thetruck was done, i am almost sure it is a welded rear.
Old 03-08-2010, 06:17 PM
Junkers88's Avatar
I hope it's a spool then, you can sell those pretty quickly. If it is in fact welded then my advice would be to find a 4.10 diff that someone is selling (I'd GIVE you one of mine if you were close enough to drive to) and swap out the gears and install a locker at the same time.
Old 03-08-2010, 06:20 PM
DanStew's Avatar
Yeah I am lookingto have to reset the gears myself. I have to get to learning how to do the yota gears. I have done Danas but not a yota yet. Oh well I will get it done.
tHanks!!
Old 03-08-2010, 06:58 PM
Junkers88's Avatar
tHanks!!
Dana's? What did you run before? I ran Scouts for a long long time before I got into Yota's.
Old 03-08-2010, 07:07 PM
yotaman85's Avatar
every time anybody wheels a scout, a baby is killed in Africa. just say no to scouts!
Old 03-08-2010, 07:14 PM
Junkers88's Avatar
Oh man that's just wrong...... *LOL* I loved my Scout although I hated trying to find parts.
Baby killer, in diesel thank you very much.
Old 03-09-2010, 02:15 AM
DanStew's Avatar
I ran Jeeps. Never had a scout, but do like them alot.
Old 03-09-2010, 05:28 AM
stock as possible's Avatar
If you decide to regear your rear yourself, I've got a nib 4.88 ring & pinion and a used 4.88 IFS chunk sitting in my shop. The front diff has two chipped teeth on the ring gear, so it needs some work, but they're available. I'm near Fayetville NC if you're ever up that way.
Old 06-20-2010, 12:23 PM
4x4jeffyota's Avatar
are welded diffs. a good idea?
Old 06-20-2010, 12:41 PM
rattlewagon's Avatar
the search button is a good idea
depends on what you do with your truck. It the cheapest way to lock your rear end and provides the most traction. Im a fan of them.
Old 06-20-2010, 01:04 PM
Fossilized
Staff
dropzone's Avatar
downside...tire wear, learn to rotate often or have a steady supply of them
Old 06-20-2010, 06:07 PM
i tried to do some research about em but no luck. ok thanks, i prolly just save and get a locker, prolly cheaper in the long run
ladybugRC
458
08-21-2020 10:41 AM
live4soccer7
05-11-2016 06:52 PM
Badlander
10-10-2015 08:05 PM
Odin
09-26-2015 06:56 PM
toyotasaurus
09-24-2015 03:30 PM
Quick Reply: Welded Diff
