Weird possibly electrical problem?
Old 09-29-2010, 04:45 AM
SHIFTER's Avatar
So i hadnt driven my 88 for ~2 weeks since we were out of town, and it ran great before we left with no issues. So I took it for a drive last night and it drove great until it was warmed up. Once it was warmed up the motor started dieseling at idle (dropping rpms, then going back to idle... kinda like a DSM does for instance). Then as soon as I get into the throttle and start moving BOTH the brake light and Charge light come on. As soon as I let off the throttle they go away again.
WTF is going on... I got it home, but im assuming the alternator is not charging or something. any ideas?
Old 09-29-2010, 04:46 AM
SHIFTER's Avatar
I should mention i just did a top end rebuild that has less than 100 miles on it.... however all was running fine until i let it sit for 2 weeks.
Old 09-30-2010, 04:26 PM
StaSta's_Yota's Avatar
man twinzies or something!!! im freakin out cuz today less than two hours ago my 88 did something VERY similar...drove all day no prob than turned it on leaving a store...boom brake light, charge light, idles 200rpm higher than normal, then on top of that temp guage is reading 3/4+!!!! im freakin out...im not a fan of takin my stuff to shops....any ideas would be temendously appretiated...
Old 09-30-2010, 05:28 PM
92YotaPickup's Avatar
My 92 had a problem like that last year it did once on the way home then stopped and then the next day did it on the way to work, and then again on the way home but that time it dead out and I all of the sudden had no power from the battier, was able to boost it and get it home.
Changed the battier and it was fine.
Not sure about yours but maybe check that battery and alternator
Old 10-03-2010, 11:36 AM
bbyeahwhatever's Avatar
Probably a bad alternator. Mine was still charging but would drain my battery when not running. My lights also came on every so often.
Old 10-17-2010, 09:27 PM
skoti89's Avatar
also experiencing the same problems. Im putting in a new battery and a GM alt. I'll post up if it works or not.
Old 10-17-2010, 09:29 PM
camo31_10.50's Avatar
i say Alt.
faster it spins, more amps it puts out (until a certain point.)
sounds like it's dead to me?
Old 10-17-2010, 09:37 PM
peow130's Avatar
Sounds more like the regulator than the alternator itself
alternator is putting out amps, regulator isnt regulating.
Old 10-18-2010, 07:36 AM
wickedlowss's Avatar
Alt.
My truck did the same thing when the alternator died.
Old 10-18-2010, 05:25 PM
SoCal4Running's Avatar
This is because your alternator belt broke. The alternator and the water pump both share the same belt, when it brakes the charge lite and the brake light both come on, the motor starts to overheat because the water pump has stopped pumping and your idle RPM increases because it now has a lot less drag to deal with sans the water pump and the alternator.
Old 10-19-2010, 04:03 PM
PriME87yota's Avatar
My truck did the same thing and i added a extra body ground to it and it hasnt done it sence. Thats from the block to the body bye the way lol.
Old 10-19-2010, 04:17 PM
Swimmerboy2112's Avatar
You're car is mad at you for leaving her for 2 weeks!
Na, it's probably just your alt.
coryc85
09-09-2015 06:24 AM
Yota.Jay
07-23-2015 08:08 PM
icentropy
07-14-2015 10:23 AM
Poncho0206
07-10-2015 06:21 PM
AaronM
07-08-2015 07:15 PM
Quick Reply: Weird possibly electrical problem?
