weird noise
weird noise
i have an 88 pickup with the 22re but when i get the motor to about 3000 to 3500 rps it sounds like the fan is hitting something. there is no check engine light and as soon as i get above that point it is fine again. i checked the oil fan and there is no damge.
it has somthing to do with the power steering pump bracket cause if i put a pry bar between that and the header and pull a little bit it will stop. in the power steering bracket how many bolts hold it to the block?
Motor Noise
And previous post is right as well , if your motors mounts are broken or heavily worn it could be that as well
1 Post
wow you guys are really mean he has a real problem and from being really tired just like me messed up on one word just like me and everyone gets on him for it dude i hate to say it but i had the same but mine was a lower end knock and a very lose chain take the valve cover off and see how play is in the chain mine had about 2 to almost 3 inches of play then it locked up woo whoo new motor with a heavy cam coming soon!!
zytra
01-24-2019 03:16 PM
zombie_barbarossa
10-02-2015 10:54 PM
