Weird electrical issues...
For the past couple of months, if I start from a stop a little slow, my stereo would shut off and come back on when I got the RPMs back up to 800 or so. I didn't think anything of it because my system draws alot of power.
Today, when I turned on any electrical switch (Blinkers, fan, AC, etc...) the stereo would shut off and come back on, and when my blinkers were on my dash lights would flash between dim and bright.
I got a new interstate battery in february... so I doubt that is the problem.
Is there maybe a single fuse that is a master fuse for all of the cabin electronics?
Weird electrical problems always seem to end up being the alternator. Search "weird" and most likely, you'll come up with posts about two things; the alternator and Swampthing.
radio and weird problems with electrical
weird electrical problem...
92 4runner weird electrical problem...
Electrical problems on my 88 Toy
"Weird electrical" search results
I bet you find you need to replace the alternator brushes (about $10). The part is the same whether you have a 22RE or a V6, my autoparts store said they only had the V6 alternator brushes, and I have a 22RE, I bought them and installed them and the alt works fine. Whole job takes less than 2hrs for an amateur providing you can figure out how to solder.
It is a one beer job. I'll pm you my address if you want to send me a check for the money this is going to save you.
zombie_barbarossa
10-02-2015 10:54 PM
