Weird cooling issue w/ 22re - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 09-25-2006, 01:21 AM   #1 (permalink)
Hi guys, new to the forums here, just recently bought a 91 Toyota Pickup 22RE 2WD A/T to use for our mt. biking trips. My dad borrowed the truck today and he told me that whenever he took the truck up to 70 - 80mph, the temperature needle would start to climb. I am assuming that the radiator is clogged (but can a bad rad cap do this also??). I also noticed that it takes a really long time for the truck to achieve normal temperature (usually about 15minutes??) is this normal also?? what can you guys recommend me to check?? thanks, aight peace
- Bert
ps- I did a search and didn't seem to find anyone with a similar problem as me.
boostaddctn is offline
Old 09-25-2006, 05:11 AM   #2 (permalink)
mt_goat's Avatar
Does it over-heat when the heater is on? Check this out: http://www.4crawler.com/4x4/CheapTri...tml#Thermostat
__________________
~Dale~
93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift front, Alcan springs rear, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" Body Lift, 1.5" ball joint spacers, manual hubs, TJM T-17, Warn m8000.
mt_goat is offline
Old 09-25-2006, 07:01 AM   #3 (permalink)
if you just bought it its usually a good idea to swap fluids. I would drain and flush the rad, replace the t-stat, and replace the cap.
MMA_Alex is offline
Old 09-25-2006, 07:39 AM   #4 (permalink)
Elton's Avatar
Send a message via AIM to Elton Send a message via MSN to Elton
Welcome to YotaTech ... try replacing the t-stat and see if that helps any
__________________
My Truck 98 4runner SR5 3.4L 5spd 4x4 E-Locker Mods
Mom 07 Tundra d-cab limited 5.7L 4x4 auto
sister 92 pickup SR5 X-cab 3.0L 5spd 4x4
Papa 89 Pickup SR5 X-cab 4x4 3.0L 5spd/98 4runner SR5 4x4 auto 3.4L
R.I.P 91 4runner SR5 4x4 3.0L 5spd Totaled 5/13/06 My Wreck
Elton is offline
Old 09-25-2006, 09:27 AM   #5 (permalink)
Flash319's Avatar
Sounds like your t-stat is no good as it should only take a few min to warm up. Also your rad is probebly on its way out.
Flash319 is offline
Old 09-25-2006, 10:04 AM   #6 (permalink)
Glenn's Avatar
Also check out the fan clutch. I have had the same symptoms you describe, and it turned out to be the fan clutch was not working right.
__________________
-Glenn-
Glenn is offline
Old 09-25-2006, 10:06 AM   #7 (permalink)
04 Rocko Taco's Avatar
Send a message via AIM to 04 Rocko Taco Send a message via Yahoo to 04 Rocko Taco
I was going to say sounds like a t-stat, fan clutch could be a good idea too. But yeah when having these issues, alwaysa good idea to go ahead and do a rad flush.
__________________
-Chris Tread Lightly!
04 Double Cab PreRunner. 3.4 - Auto
84 4Runner 4WD. 22R - 5 spd Lifted, Locked, 33x12.50
Disclaimer:My Photobucket is being revamped. If there are broken links, shoot me a PM. Thanks. ~Chris
Great Toyota Tech
04 Rocko Taco is offline
Old 09-25-2006, 10:12 AM   #8 (permalink)
the fan shouldn't make a difference at 80mph as it is only used to pull air across the rad when the engine is idling, or going very slow
MMA_Alex is offline
Old 09-25-2006, 01:01 PM   #9 (permalink)
Quote:
Yeah thats why I didn't mention the fan clutch, cause usually after 40mph (I believe) the fan isn't needed anymore... I am going try and find time to do the thermostat and a coolant flush this weekend, any other input would help also, thanks aight peace
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
weird cooling problem elkdog 86-95 Trucks & 4Runners 6 06-13-2009 10:09 PM
weird timing issue surfcaster 86-95 Trucks & 4Runners 6 08-30-2006 05:49 PM
Weird Starting issue UKMyers 86-95 Trucks & 4Runners 15 05-20-2006 11:41 AM
What part is this?? Cooling issue. Funk_Runner 95.5-2004 Tacomas & 96-2002 4Runners 13 11-08-2005 11:11 AM
Weird cooling issue. 88RunnerV65Spd 95.5-2004 Tacomas & 96-2002 4Runners 3 11-19-2004 05:05 PM
2009 InternetBrands, Inc.
