Weber Conversion
Old 02-19-2009, 09:09 AM
hog_hunter_19's Avatar
Weber Conversion
I have an 87 Pick up with a 82 22r. I just switch out stock carb with a Weber 32/36 DGEV I believe I have everything hook up properly. I am having trouble with cranking the truck. If I spray Starting Fluid in the Carb it will crank until it runs out of Starting Fluid. I'm not sure if I need to adjust the choke some how. My first thougt was it wasn't getting any fuel in the bowl. I checked and plenty of gas. Any suggestions. Also how many psi does stock Fuel Pump produce.
Old 02-19-2009, 09:32 AM
abecedarian's Avatar
does the weber have the fuel cut solenoid? if so, is it operating properly?
Old 02-19-2009, 12:57 PM
No Fuel Cut Selonoid.
Pri$erulz
11-17-2019 08:03 PM
live4soccer7
05-11-2016 06:52 PM
kawazx636
09-29-2015 08:22 AM
runnermedic
13
09-21-2015 05:20 PM
Quick Reply: Weber Conversion
