Weber 32/36 high altitude questions
Old 08-26-2010, 09:57 PM
yotaman90's Avatar
Is anybody running a Weber 32/36 at high altitude? If so, how does it perform? I'm preparing to order a 32/36 and I'm wondering if it would need to be rejetted since I live at and above 6900 feet. Any help is appreciated
Old 08-27-2010, 11:14 AM
yotaman90's Avatar
Seriously, nobody?
Old 08-27-2010, 11:57 AM
T_F_E's Avatar
Should be fine, you just have to adjust it according the the air. I lived at 10,000 feet for 16 years, just need to set it more lean than factory specs because there isn't as much air.
Old 08-27-2010, 12:56 PM
yotaman90's Avatar
Cool, thanks!
Old 09-06-2010, 07:45 PM
yotaman90's Avatar
Well, got my Weber a few days ago and installed it. It seems to run ok, but it has a funky idle. Sometimes it will idle perfectly, but most of the time it tends to surge. What could it be? I'm sure that I don't have any vacuum leaks, does it point to my altitude? Also, I'm not running a fuel pressure regulator seeing as the one I had was a Spectre piece of crap. Any ideas?
Old 09-07-2010, 06:34 AM
yotaman90's Avatar
Bump!
Old 09-07-2010, 08:16 AM
toyotasaurus's Avatar
First off, get a new regulator. Then double check your vacuum lines for leaks. After those two items are covered, adjust the idle mix screw and see where it's at to determine if you need a new idle jet.
Old 09-07-2010, 12:59 PM
yotaman90's Avatar
Found the problem. When I removed the primary jet holder from the side of the carb to replace it with an anti-diesel solenoid, I forgot to take the jet from the holder and add it to the solenoid . Replaced the jet and all is good now!
kazuya2416
04-05-2024 02:17 AM
calderp
Engine Swaps
08-16-2016 05:15 PM
dumpster84
04-30-2016 06:03 AM
calderp
07-27-2015 09:58 AM
Quick Reply: Weber 32/36 high altitude questions
