water pump weep hole? - YotaTech Forums
Go Back   >
LinkBack Thread Tools Search this Thread
Old 01-07-2007, 12:22 PM   #1
PabloA's Avatar
on an 94 pickup 22r-e anyone know if the water pump has a weep hole and where its located?
Thinking I might need a pump. Getting a lot of dark built up dirt below water pump.
PabloA is offline   Reply With Quote
Old 01-07-2007, 01:29 PM   #2
drew303's Avatar
weep hole?
Theres only one hole on that water pump and thats where the shaft comes out that mounts to the fan.
It's not uncommon for the seal around the pump to go to but usually the shaft seal wears out.
Water pumps are only $25-$30 or so at a parst store.... then cost of fluids. Easy fix imo (done a few)
drew303 is offline   Reply With Quote
Old 01-07-2007, 02:49 PM   #3
mr toytech's Avatar
all toyota pumps have a weep hole. they usually right under the pully shaft bearing. and they will start to leak from there if the front seal is going bad.
mr toytech is offline   Reply With Quote
Old 01-07-2007, 08:42 PM   #4
PabloA's Avatar
can this weep hole be visually seen from outside the pump?
looking from underneath the truck?
Whats a good pump to get? aftermarket or dealor?
hey drew303, clean truck man!
Another timing chain question thefishguy77 Newbie Tech Section 10 07-30-2015 11:59 AM
Need Help: 22r overheating Logz808 86-95 Trucks & 4Runners 3 07-26-2015 08:09 AM
No heat jjrbus 86-95 Trucks & 4Runners 5 07-19-2015 03:06 PM
22RE Leaky Water Pump Gasket Snort 86-95 Trucks & 4Runners 4 07-19-2015 08:03 AM
Water pump issues and repairs Jonny246 86-95 Trucks & 4Runners 4 07-12-2015 05:51 AM
Tags
22re, gasket, hole, jeep, leak, leaking, pump, purpose, seep, thermostat, toyota, water, weap, weep, weeping
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
