Water pump gasket question
Staff
I am guessing that is a 3.0 gasket? I like the idea of the rubber seal on it. I personally would put a thin coat on both sides. I have not done a 3.0 water pump gasket but some one with experience on it will give better advise.
The gasket that came with the AISIN WP is a fine gasket. It's been installed as-is without RTV or any other additional goop on several 3.4 WPs I've done and never have had a single issue. I see no reason why the performance on the 3.0 will not be the same.
Do what ever makes you happy.
If you don`t do the blue silicone I myself would wonder every time I went some place is now the time it starts to leak.
I know in my case it is all physiological
We all have our on thing Just like I refuse to weld on a vehicle without removing the negative battery terminal.
09-04-2015 09:27 AM
TURBOrunnerNM
07-22-2015 11:01 AM
Avenged
07-09-2015 07:55 AM
