| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
water by-pass gasket on 3VZE
#2 (permalink) |
YES you need a torque wrench.
Follow the fsm torque specs.
__________________
91 Pickup - xcab - 5sp - 3.0 - SR5 - 4x4 - 250k |2.25" catback w/ magnaflow cat + glasspack | Weasy2k cams | Aisin manual hubs | Diff breather mod| Marlin HD clutch |3" BL | es3000's |2" AAL |1.5" bj spacers | ISR | Alpine headunit | 4" Infinity fronts/5" rears | 4.88's |Rear lockright | 33x12.50" BFG M/T on 15x8" steelies |Hella 500's |4" reverse lights| Grant GT |idler arm brace|hella E-codes| Marlin armor |SS IFS brace | %100 Amsoil synthetic http://www.cardomain.com/ride/2572486 |
#3 (permalink) |
My favorite FIPG is called "The Right Stuff" by permatex. It's a thicker feeling gasket maker than most other stuff you buy, and it's compatible with all vehicle fluids. If done correctly, FIPG will seal as well as an o-ring.
Yes, the water bypass is under the same pressure as the rest of the cooling system. You can't properly torque anything to 43 in-lb using a ft-lb wrench (since 43 in-lb is about 3.5 ft-lb), and torques that low are hard to do by "feel" unless you have a lot of experience. You'll probably be OK by just snugging it up (as long as you don't strip the threads), but If you're going to be wrenching regularly on your truck, you should buy an in-lb wrench anyways, and do it right.
__________________
2002 4Runner, Auto-A340F, 3.4L, 4.30 Gears TJM T15 Front Bumper & Warn M8000, 4xInnovation sliders, Sonoran Steel 1.2 Lift, Toytec LCA Skids, Tundra Brake Upgrade (231mm), Extended rear diff breather, Deckplate Mod, Andymod, Dual batt setup with Optima blue top aux battery, Hardwired 1000W inverter, Aux fuse box, Full time power to 12V plugs, Yaesu FT7800R Radio, "4-air" system for airing up/down tires. 2004 Camry LE - stock (and will stay that way) 1993 4Runner has been sold |
#4 (permalink) |
took your advice and bought an in-lb torque wrench. no regrets as there are several bolts that require that range. did the oil pan and water by-pass last night with peace of mind.
thanx for your assistance |
#5 (permalink) |
Yo,
From hard-headed experience, I have tried to use dense cardboard to make both water and oil gaskets with failed attempts at both. The cardboard will absorb both the oil and water and ultimately create a failure at a bad time. Don't put an o-ring where its not designed nor use a "close enough" o-ring sitting in your tool box. In the case of the bypass pipe, put on what Toyota recommends. The tear down to fix a screw-up here would be extremely painful. You may want to replace the knock sensor cable. They become brittle over time and have a history of failing. Another PITA to redoo. My $0.02
#6 (permalink) |
little late for the knock sensor wire thing, however, i noticed mine was kinda new looking. i think it may have been changed about 2 yrs ago when i had the dealer replace a valve.
thanx for your help.
__________________
'92 sr5 xcab p'up, 4x4, 5 sp manual, 3.0L 3VZE 455K miles w/valve job @ 380K, original owner |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| leak from water pump gasket ,water pump | dcmbsc | 86-95 Trucks & 4Runners | 10 | 08-06-2007 08:46 AM |
| Where is the No. 5 water by-pass hose?? | snelson | 86-95 Trucks & 4Runners | 1 | 07-12-2007 11:07 PM |
| water pump metal gasket with seal packing | 4x4CPOSEADOG | 86-95 Trucks & 4Runners | 8 | 03-11-2007 09:50 AM |
| 3.4 Water Pump - what gasket to use? | ohio4runner4x4 | 95.5-2004 Tacomas & 96-2002 4Runners | 14 | 02-23-2007 03:19 PM |
| Water pump gasket? | vegaskurt | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 11-29-2005 05:02 PM |
