water outlet on bottom of intake manifold SUCKS - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 06-18-2008, 09:39 AM   #1 (permalink)
kd
is there any trick to putting this on. its sandwitched between the starter ans intake manifold stud coming out from the head. so it has to be put on in place i think. just messed up a good manifold because of this thing
__________________
'86 4runner AT
kd is offline
Old 06-18-2008, 03:30 PM   #2 (permalink)
abecedarian's Avatar
Location: @ work somewhere between Walla Walla, WA and Lewiston, ID
umm... if it's between the starter and the manifold...
why not remove the starter?
__________________
Quote:
Originally Posted by DeathCougar View Post
Abe so far has been spot on, 100% correct. As usual
Insomnia: it's a way of life.
abecedarian is offline
Old 06-18-2008, 09:46 PM   #3 (permalink)
This thing screwed me over when I replaced my headgasket.
What I did was loosen the fuel filter frame (what you are mistaking to be your starter) from the block, and created enough space to install that metal water hose. Without doing that, I saw no way of completing the install.
It set me back a good 3 - 4 hours, and I feel your pain. It annoyed the out of me, and many times I considered simply cutting it and running heater hose around the engine (although we all know that is a terrible idea!).
After all the work, I don't think about it anymore, but, I definitely sympathize with you.
Best of luck.
khany2002 is offline
Old 06-18-2008, 10:03 PM   #4 (permalink)
kd
thanks i realized it was the fuel filter and decided to replace it because there is almost no way to get in there without pullung the manifold and i dont want to do this again it i dont have to. im supprised how difficult it is to work on this motor. its like you need the hands of a small child to get to some of these areas.
__________________
'86 4runner AT
kd is offline
Old 06-19-2008, 02:29 AM   #5 (permalink)
Send a message via Yahoo to Ezrider_92356
i had a hell of a time with that one as well, removed the fuel filter and the fuel filter mounting bracket.
Ezrider_92356 is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Stock Intake Manifold ?. myyota 86-95 Trucks & 4Runners 6 05-06-2008 11:06 AM
Coolant leak from Head Bolt and Water Outlet? Nuckaman 86-95 Trucks & 4Runners 2 10-18-2007 12:10 PM
3vze water outlet question the_supernerd 86-95 Trucks & 4Runners 3 01-22-2007 09:09 AM
Intake Manifold blainelukens Maintenance & Repair Archives 15 04-17-2005 10:57 AM
3.4L Intake Manifold Yosmany 95.5-2004 Tacomas & 96-2002 4Runners 3 03-30-2004 08:11 PM
2009 InternetBrands, Inc.
