Water Logged 4runner
Old 07-22-2009, 01:42 AM
UrbanAsault's Avatar
Hey Peoples.
I Drowned my 4runner on the weekend..
more importantly pix
Now..stop laughing.. k thanks
so its got the 3vze v6
we pulled her out to shallow and took the air intake off which has water in it :S
yanked the plugs out and cranked her ova
http://thegeekman.com/Movie.WMV
she seems to crank fine and free
ECU is giving me a im ok signal after a good clean with silicon
I have spark
And fuel is firing.
new oil to
before i go wack some new plugs in and try and get her to fire is there anything else i can do?
Old 07-22-2009, 05:06 AM
bigtrucknwheels's Avatar
Location: Where it always works if you work it, in Sunny Selinsgrove, PA
sounds like you got it all covered... looks like you had fun!
Old 07-22-2009, 05:18 AM
drew303's Avatar
maybe clean your seats with some good upholstery cleaner, dont wanna get it all purring again have a stinky interior... =P
Old 07-22-2009, 05:23 AM
96redtoy's Avatar
Don't forget about about all dif, trans, and transfer case oil change
Oh and I just went through the same thing
I ending up having to replace the rear main seal the pilot bearing, the clutch through out bearing, and for good measures I replaced the clutch and pressure plate. Had to get a new starter and had to drain $100 of royal purple from the drive train. It was one expensive little swim, to say the least.
Oh and there is still a frickin grinding sound of some unknown bearing some where that I cant find.
Good luck and it sounds to me that you are taking all the right steps
Oh for some strange reason your steering wheel must of been afraid of the water and jumped to the other side of the truck; you might want to have that looked at.
Old 07-22-2009, 05:33 AM
yoder519's Avatar
reminds me of when i sunk mine. but yours look s awee bit worse. make sure you suck all that water out your carpet with a shop vac or somethin, i just ripped mine out and herculined it
Old 07-22-2009, 04:53 PM
woodendude's Avatar
I've done this twice to mine and when she stalls out the exhaust becomes a vacuum, you should probably pull the exhaust from the cat back and run water (garden hose) through it until it comes out clean. The mud melts the cats honeycomb pretty quickly when it's plugged up.
Old 07-22-2009, 05:08 PM
hehe you silly buggas drive on the wrong side of the road nwahaha ..
Thanks for all your advice
Ill post up come the weekend and let ya kno how i go
Some More Pix
Old 07-22-2009, 05:19 PM
tesh's Avatar
man oh man! what's the story behind that lil trip?
Old 07-22-2009, 06:08 PM
Just Bought her
went for a quick run to test her out!
haha nothing better than killing your week old 4b
Old 07-22-2009, 06:11 PM
tesh's Avatar
Originally Posted by UrbanAsault
Just Bought her
oohhhh mannnnn!
well welcome to the site! these yota-techies will have you fixed up in no time!
EDIT: when i was in england i remember seeing the "L" and "P" stickers... just got your license??
Old 07-22-2009, 06:27 PM
Whats worse is that i got pulled out by a nissan
Old 07-22-2009, 06:36 PM
Unkn0wn's Avatar
Silly Yoda's.
Those nissan's that were ahead of you, told you to go around the big dip, but no you went straight in.
Tis your own fault
Fix it already, im planing another trip where we can watch you break more of your cars.
Old 07-22-2009, 06:49 PM
PFFT nissan owner
ehehe
kk ill get to it sat prob no beach runs tho.. maybe some hills
Old 07-22-2009, 06:51 PM
CRafferty's Avatar
Originally Posted by Unkn0wn
Silly Yoda's.
Tis your own fault
That's nasty. Nissan makes overland capable vehicles? I was unaware..
Old 07-22-2009, 06:59 PM
btw.. before mods freak out.. IP address is same cause we work for the same company haha
Old 07-23-2009, 12:45 AM
So on what level of screwed do ya think im on?
1 its fine just needs to dry out
10 its Screwed new engine time
Old 07-23-2009, 08:40 AM
PlugItIn's Avatar
3...i sunk my 22re far worse. It was not fun, but she's still going today. I didn't really have to do much other then change all the fluids (it gets expensive, fast) Had to take the interior out to let her dry. You might want to check out the hubs and bearings in the front if it sat in the water for a while...
Old 07-23-2009, 12:53 PM
fireman1559's Avatar
wow ive done some crazy things in my truck but dang never sunk it hahahaha looks like yall had fun thou. it sounds like u have done everything needed so you should be good just dont forget to change trans and xcase and front and rear diff fluid
Old 07-26-2009, 09:32 PM
SOOO.....
New oil
new oil filter
dead alternator.
:S
so looking for alternator atm.
I started her up this morning and she blew enough smoke to start your own rave..
id say its the extra oil burning off as i but in 5.5L instead of 4.3L i should of.
There is no knock or miss. but the engine is making a god allfull noise which i think is the alternator. the engine light is on and so is the battery light
Also it is going in and out of 4H by itself so id say there is something wrong with the actuator or the control box.
Also.. the oil i pulled out.. was brown.. no so good
icentropy
09-16-2020 02:47 PM
09-04-2015 09:27 AM
shar
07-09-2015 12:38 PM
Avenged
07-09-2015 07:55 AM
Huntingtruckcletus
07-08-2015 05:26 PM
Quick Reply: Water Logged 4runner
