Water leak!?
Water leak!?
I have a water leak around my drivers side exhaust manifold. its dripping off the inside bolt and cant tell where its coming from. i hope its not a headgasket but if anybody knows if theres a freeze plug in that area or know for sure its a headgasket that would be great. its not pouring its just a good dribble.
There is a coolant hose that runs to the throttle body which is above your driver's side exhaust manifold, could it be coming from there? If you can't tell, clean off all of the mess as best as you can drive it for a bit then inspect again.
WellsR
12
07-31-2015 03:27 PM
TJWilly
07-31-2015 02:05 PM
Avenged
07-09-2015 07:55 AM
