water is disappearing!! 87 4x4 22r
Old 05-09-2010, 09:41 PM
big87toyota's Avatar
I have a 87 4x4 with the 22r I have compleatly built this motor from ground up all new been running for bout two years and recently its been over heating after quite a long drive and every time it over heats it takes a gallon of water but I have no water leakes and I have put a new radiator new water pump thermosat I can't figure this out my compresion on each cylindar is 125 also is that low and where is my water going please help
Old 05-10-2010, 07:02 AM
yayfortrees's Avatar
Please search, there are at least 2 or 3 threads that are identical to this. (Probably dozens)
Also, grab yourself a manual. It is the most reliable source of information, and the fastest way to get it. You can get it from here, I hope you aren't using dial-up:
http://ncttora.com/fsm/1985/1985FSM_OCR.pdf
And yes, 125 PSI is low.
Welcome to YT.
Old 05-10-2010, 07:19 AM
Lumpy's Avatar
Yes, search around a bit. But I'll help ya out a bit. Sounds like the HG is going/has gone/is on it's way out. Click on the FSM in my sig for help.
Old 05-10-2010, 08:45 AM
alright thanks i found some other forums on my issue
Old 05-12-2010, 02:45 PM
offroad1990's Avatar
hey where did u find the help with your water disaperence?? cause im haveing the EXACT same problem with my 89 V6 4runner. .
Old 05-12-2010, 08:50 PM
LITLRED's Avatar
Originally Posted by Lumpy
Yes, search around a bit. But I'll help ya out a bit. Sounds like the GH is going/has gone/is on it's way out. Click on the FSM in my sig for help.
You mean HG?
Old 05-12-2010, 09:22 PM
DoveGray85's Avatar
Same here. I have to add water every time I drive my truck. I'm pretty sure it's the head gasket. I also see white smoke coming out the tail pipe sometimes.
That's a bummer you only got 2 years out of the motor before having problems, big 87. Maybe try re-torquing the head bolts?
I'm building a motor right now, out of a 2nd block I picked up. My plan is to use a mls head gasket and ARP head studs. I'm also having the block decked and buying a new head. I hope to avoid head gasket problems. There are constantly threads on here about blown head gaskets.
Old 05-13-2010, 04:58 AM
Lumpy's Avatar
Originally Posted by LITLRED
You mean HG?
Yessir, fixed...I do that sometimes...
Old 05-13-2010, 11:53 AM
thats what i thought it woulb be, the head gasket, but i doesent leak water from nowhere at all,, so wouldnt it leak if it was the HG??
Old 05-13-2010, 11:57 AM
camo31_10.50's Avatar
mine doesn't leak water anywhere..but i'm putting out a HUGE cloud of White smoke..and the overflow tank is full, and overflowing actually.
i'm about 95% sure it's my headgasket..i only got 9500-10,000 miles on my motor
smthwsn357
12-04-2023 02:08 AM
raptor510
02-17-2017 07:11 AM
09-04-2015 09:27 AM
Jonny246
07-12-2015 04:51 AM
cars-guy
07-11-2015 07:51 PM
Quick Reply: water is disappearing!! 87 4x4 22r
