warning!!!! danger will robinson!
so i had a break light out... no biggie. however i thought i might upgrade to LEDs! BAD MOVE! The led stopped my cruise from working! turns out that the cruise gets a signal from the brake/turn signals! so the sell a resister for this at autozone, easy enough! WRONG! wow what a fire hazzard waiting to happen. i put them in line as instructed. they warn they will get warm. warm?? these things melted the paint on the inside of the area that is behind the tail light in 2 mins. it could have been less then 2 mins im not sure but wow!!!!!!!!!!!!!!!! so im back to regular bulbs and the cruise works again!!!
it sounds like you just messed up on the wiring to me.
Every cruise control system I've seen works off the brake sensor at the brake pedal. Its a momentary switch that's on when the brakes aren't being used (the pedal pushes up on the button) and off the second you start pushing down on the brake (the button releases).
ah sorry forgot about that too. There's actually 4 ways to turn off cruise control now that I think about it.
1) hitting the brakes
2) hitting the clutch
3) pulling the e-brake (because the brake indicator on the dash turns on)
4) low brake fluid (because the brake indicator on the dash turns on)
So basically 3 and 4 are the same thing. Hitting the clutch or brake will turn it off and if your brake indicator light turns on the cruise will turn off also. 4 is a safety feature in case your brakes fail or are running low on fluid.
i hate those led pluc and play small bulbs. they are crap and dont light up for . they are dangerous, and people dont realize how little they light up in the stock housing in that they shine outwards and do not reflect off of the tailight housing.
Not sure about this specific Yota, but some systems use a dual switch down at the brake pedal (4 wire, one housing). One switch is for the cruise control and the other for brake lights. On this type of system the cruise control module will use the brake light circuit for a ground. This is a failsafe type system so that if the cruise control brake switch fails, when the brake lights come on the cruise control module effectively loses its ground and shuts off anyway. Incidentally, if both brake lights are blown you won't have cruise control. I think Ford has been using this setup for awhile, and I know for a fact the brand I work on does.
1 Post
so is it if you have leds in your brake lights your cruse wont work? cause my cruse never worked the po said it did and two days after i got the truck i did the led mod? so im guessing thats what did it then?
p.s. when i try to get it to work the light on the dash flashes( the cruse light)
cruise control on 97 4runner
went to toyota dealership today and they told me my computer on my cruise was out...was gonna cost 2200 to fix ....is there anyway around this other than aftermarket cruise......pm me and let me know please!!!!!!!!!
Junkyard or used off the internet - it should be an easy enough install that the dealer doesn't have to do it
sonorn67
09-19-2015 05:39 PM
FS[PacNorWest]: 1993 4 Runner, V6, 4wd, Auto,
AkitaDog
09-03-2015 09:01 PM
Odin
07-15-2015 09:28 PM
