Warn Rock Crawler
Old 02-17-2014, 04:51 PM
94NYToy's Avatar
Warn Rock Crawler
Picked up a used Warn Rock Crawler front bumper and tried installing it today. It did not come with any hardware, just the brackets and bumper itself. I followed the instructions from warn. Since I did not have the spacer plates I used some washers between the frame and the brackets. It seems that the bumper is riding too close to the grill and I cannot get it to fit. I'm trying to use 1 1/2" long carriage bolts, should I be using longer? The only other option I could see to mounting it would be to cut the grill a little bit, but I feel it shouldn't be necessary. I'd really appreciate some help.
1994 4WD DLX 3VZE
Old 02-17-2014, 05:00 PM
rattlewagon's Avatar
Pictures would help.
Old 02-18-2014, 03:44 AM
wyoming9's Avatar
Red face
Carriage Bolts ??
Well if it is to close to the grill move it out away from the grill.
Simple matter to make some spacers .
How much do you need to move 1/8" or 1/4" I doubt much more ??
Is this bumper made for your truck or a truck not even close??
Old 02-18-2014, 08:53 AM
93Xtra-Cab's Avatar
Originally Posted by wyoming9
Carriage Bolts ??
My thoughts exactly. For a bumper, especially a heavy offroad bumper, you will want grade 8 hardware. I'm gonna assume you got these carriage bolts from your local hardware store. Regular hardware store carriage bolts are generally grade 5 or less. Grade 8 carriage bolts are out there, but are not generally used in automotive applications.
Old 02-18-2014, 09:13 AM
highonpottery's Avatar
maybe since its used, the bumper has seen some sort of contact with something in the past which bent it slightly? Definitely want grade 8 hardware, always.
Old 02-18-2014, 09:24 AM
93Xtra-Cab's Avatar
^This. When in doubt, go grade 8.
Old 02-18-2014, 09:51 AM
94NYToy's Avatar
I'll try to get some pictures up if it ever stops snowing in NY when I have free time.
Here is the link for installation instructions from Warn [URL]http://static.summitracing.com/global/images/instructions/wrn-68466a0-pn68450.pdf
I did verify that I have the correct bumper through the part numbers.
And I definitely made sure that I got all Grade 8 hardware or Grade 10.9 in the case of the metric bolts.
I looked over the bumper a few times and it doesn't appear to have any damage or tool/machine marks from a repair. But I will check again, the thought didn't cross my mind as I was attempting the install.
I spoke to a representative from Warn today and was able to order the frame spacer places that I assume are causing me some issues. I'll update everyone when I get these in and can give it another shot.
Old 02-18-2014, 04:10 PM
wyoming9's Avatar
Red face
This bumper has notches in the mounts for carriage bolts??
It should quit snowing about the second week in May
Old 02-18-2014, 04:46 PM
fastkevman's Avatar
Wow, last time I logged in was 2/11/12, didn't think it was that long ago!
Pics would be a big help.
I've had that same bumper on my truck for about 5yrs and it is mounted perfectly level and even from side-to-side, I'm sure that I can help if I could see what looks different on your truck compared to mine.
smilen724
13
11-08-2015 04:11 PM
myotherrideisayoshi
09-29-2015 05:41 AM
crash813
09-27-2015 07:15 AM
Toys4parts
09-26-2015 01:56 PM
Project90
09-24-2015 11:40 PM
Quick Reply: Warn Rock Crawler
